Just water pump start
Check the water supplies at the back, if the valve is opening, and the water is getting into the machine, it can be a faulty water level switch, or membrane sensor, depending on the model.
A faulty or clogged inlet valve can also close few seconds from opening the valve, usually becausu of a faulty solenoid.
If valve and water level switch are ok, then this is a faulty control.
Have valve and water level switch checked first.
