I can not seem to change the M (Meters) to yards I cant work out how much 100 metres a yard is.
All I Do know is that
Number of yards- x36 -- x 2.54 -- Divided by 100 -- Gives you yards converted to metres.
From What I Have Done, I Got An Awnser Of 109.36.
How?
I Done 100m*100=10,000m
10,000 /2.54 / 36 = 109 .36 yards.
(inverse operation)
That May Be Right But im Not Sure.
Any one Going to Help?
ShahBoii
Meters. 1 m is equivalent to 1.0936 yards, or 39.370 inches. Since 1983, the metre has been officially defined as the length of the path travelled by light in a vacuum during a time interval of 1/299,792,458 of a second.
Square metres is a measure of area. Cubic metres and cubic yards is a measure of volume. There is no conversion between them without a third dimension.
Consider a storeroom that's 40.3 square metres in area. How much stuff can you store in it? Well, that depends on how high the ceiling is. If the ceiling is 2 metres high then the volume of the room is 80.6 cubic metres. If the ceiling is 3 metres high then the volume is 120.9 cubic metres.
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower
right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will
begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature, see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to
select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the
M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite
will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Hold the back button down until it changes (meters to yards or vice versa). Momentarily push the back button to step through the modes (rain, reflectice, >150, no text=<150). To use turn on with front button, aquire target and hold down front button for 3 seconds
Understand the formula.
Converting units of measurements always requires a specific formula. The
procedure from yards to meters is X (yards) multiplied by "0.9144"
meters.
Write your formula with the number of yards. Multiply by "0.9144." For example, 100 yards * 0.9144 =?.
Use a calculator. In the example above, 100 yards * 0.9144 =?, the answer is 91.44 meters.
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Thanks for using Fixya.
