Question about Ricoh Aficio SP 6330N Laser Printer
Cannot connect with dhcp
Displays "cannot connect with dhcp"
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
1 - not connected to a server that runs DHCP
2- bad network connection
3 - set IP address manually
Posted on Mar 03, 2014
6ya staff
SOURCE:
How can i get an ip address
Firstly, what operating system are you using?
applicable for windows xp or windows 7. press Windows Key + R
select the appropriate network connection (e.g. Local Area Connection). Right click the Local Area Connection choose Properties. For windows xp, doble click Internet Protocol. For Windows 7, double click Internet protocol IPv4. choose Obtain an IP address automatically. press OK. right click again the Local area connection then choose Status. there tou can see that your computer is negotiating for an IP address from the dhcp server. if still cannot obtain an ip address, press Windows key +Run then type "services.msc". scroll down and find DHCP client. ensure that this service is running.
Please also try to check if the network you are connected does have a DHCP server.
Jul 01, 2013 | HP Compaq nc6220 Notebook
I have windows 7 home prem and cannot connect says detects strong signal but limited access
Most likely, the access point is not connected to an internet gateway whatever that is at your place.
and since access points does not provide DHCP service by default (handing out IP information to connected clients), you get the limited access message.
In short, make sure the access point is connected to the router because the router is the once responsible for providing the DHCP service.
Feb 18, 2012 | ASUS WL-330 802.11b Wireless Access Point
When i connect the phone in to network through RJ 45 cable , it displays DHCP:0,1,2.......continuing, VLAN ID=0 ,*to program. I can ping in to the network and avaya server .pls help me
Plug the phone in and dont touch it. Is it grabbing DHCP? If you get to VLAN ID=0, you are in teh programming.
Plug it in and do not touch......what happens?
Aug 14, 2011 | Avaya 9620 IP Phone
Display screen reads dhcp bad conflict
There is a dhcp error. Reboot the phone.
When It says, DHCP * to program, press the STAR button.
when the IP address is displayed, change it by press 0.0.0.0. Where the dots are would be the star button. then press the #(pound) button until you see save new values, press star for yes.
Hopefully that will force it to grab another IP from teh DHCP server.
If not contact your admin.
Jan 12, 2011 | Avaya 5610 IP Phone
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Dec 19, 2010 | RCA Computers & Internet
My PC is connected to this modem/router and works fine. All the laptops in the house show that they are connected but I can't get any websites on any of them. Also, when I connect the laptop with an...
Log in on your router manager http://192.168.x.x and enable DHCP.DHCP provides an automated way to distribute and update IP addresses and other configuration information on a network. A DHCP server provides this information to a DHCP client through the exchange of a series of messages, known as the DHCP conversation or the DHCP transaction. If the DHCP server and DHCP clients are located on different sub-nets, a DHCP relay agent is used to facilitate the conversation.
  1. Connect to your router (by typing 192.168.0.1 or 192.168.1.1 into the URL bar) and log in. Check your user manual or documentation if you do not know the log-in credientials.
  2. 180px-dhcp_router_setup.jpg magnify-clip.png Router Setup tab Make sure you are in the Setup -> Basic Setup category.
  3. 180px-dhcp_router_disabled.jpg magnify-clip.png DHCP is Disabled Scroll down until you see 'DHCP Server' - if it is disabled, select 'Enable'
  4. 180px-dhcp_router_enabled.jpg magnify-clip.png Enable DHCP If you want, you can change the number that the DHCP IP assigning starts. This is optional, and is totally dependant on personal preference.In this picture, the maximum number of DHCP clients is 3. You may need to increase this number according to how many people will need a dynamic IP address on your network. Once the max is reached, no one else can get an address until one expires!
  5. Use the DNS servers provided to you by your ISP, or use the following DNS servers: 205.152.37.254, 205.152.132.235, 205.152.132.23; There are many DNS servers out there. It's best to use your ISP's if possible.
  6. dhcp_router_save.jpg magnify-clip.png Don't forget to save! Scroll down and click 'Save Settings'
  7. Open up the network configurations for the computers on your network (Control Panel -> Network Connections -> Local Area Connection or Wireless Connection) and select 'Obtain IP address automatically'
Dec 09, 2010 | Actiontec GT704WG Wireless Router...
I am connected to the wireless network but cannot get an internet connection. When I launch IE it just keeps coming up with Internet explorer cannot display the webpage. I am currently in Sweden - does...
it doesnt make any difference in what coutry you are. if you say it works at home it should work in other places too.
check the ip configuration. if you have static ip&dns try to switch to automatically (dhcp). If dhcp is already set ask for network settings because maybe the access point you are trying to connect to doesn't provide dhcp or it has mac filtering.
Aug 16, 2009 | Samsung NC10-14GW Notebook
DHCP Lease Expired
Open your network folder,Right click on you network connection,select status,select repair.
close network connection folder.
Or click start,all program,accesories,command prompt,when the command prompt opens,Type ipconfig /renew
once completed, type exit and hit the enter key
Please rate this a fixya
Feb 14, 2009 | Acer AL1716 F Monitor
I have installed the drivers for both my canon imagerunner 3220 and my 3300 but i still cannot print to it or scan from it. I have the network cables connected... I can ping it do i have the right...
Enter the device IP into your web browser. This shoudl load its web management interface. If it does not, you have an IP connectivity issue. You must power cycle the unit after changing IP settings.
press additional functions, report settings, network, user data list, yes. Check to see if DHCP is enabled. If it is, the IP displayed in the report may not be correct. DHCP should be off in most cases. Verify IP shown here.
Double check for link lights on the network cable.
Jan 12, 2009 | Canon imageRUNNER C3220 Color Copier
Ricoh Aficio SP 6330N Laser Printer Logo
566 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
