SOURCE: hi we have daewoo washing machine coming error
Error code E2 is overflow problem, possibly related to the pressure switch.
If the pump runs continuously then try checking that the drain hose is not blocked or that the waste outlet is not blocked.
If that checks out OK then the pressure switch is stuck in the high level.
Take the capillary hose off from the pressure switch and blow down it to remove any residue stuck in the pipe.
