Question about Westinghouse SK-32H240S Television
At first had sound and only W would show up on LCD screen, replaced the power supply/inverter board part # 56.04264.021 and now it has no sound and W only stays on 1 second and no picture.
First no sound and now no sound and W only screen short time, after replacing board.
6ya staff
SOURCE:
Tech4lfe
Neil Frazier
  • 42 Answers
SOURCE: Westinghouse LTV-32w6 power light on, no video, no sound
One thing is to make sure the inverter board is unplugged when testing the voltages. A shorted inverter will shut down the power supply if the fuse dosen't blow first. There are fuses that don't look like fuses so they can be missed. The next thing would be to look for a connector from the main to power supply and see if there is a pin labeled power on or p.on or similar. The main board should turn this line high(5V) when you push the power button. If not you probably have a bad main board. Unless you can find good used boards they are both expensive. Around $200 for PS and $300 for main.
Posted on Jul 06, 2008
Anonymous
SOURCE: LTV-32w6 won't turn on
were on the power supply is the fuse located
Posted on Nov 13, 2008
Anonymous
  • 66 Answers
SOURCE: Westinghouse LCD tv LTV-32W4 has great sound but no picture.
Your television actually has a backlight bulb which can be replaced at our parts request email and phone number. Email address: Parts@wde.com. (866) 839-5888
Posted on Jul 29, 2009
Anonymous
  • 92 Answers
SOURCE: westinghouse 30" lcd tv has no sound no picture,but green lighton
Replace the Power Supply.
Posted on Sep 06, 2009
Chi Chu
  • 8457 Answers
SOURCE: Westinghouse HDTV TX42F430S, No picture or sound.
Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for the replacement.
Posted on Mar 17, 2010
Testimonial: "Thanks for the lead on the parts."
I have an Element tv that has no picture, good sound but basicaly a black screen. Do i need a didgital board or a main board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | Element Televison & Video
I have a lg55la6200 led/lcd smart TV. When I turn it on it stays on for about 15mins and then the screen turns off but sound still on. I have done the flashlight test and can see the picture.
Apr 22, 2017 | Televison & Video
Samsung UN55EH6000 has audio, but no backlight LED as seen with flashlight test.
http://electro-medical.blogspot.com/
Feb 29, 2016 | Samsung Electronics UN55EH6000 - 55in...
Black screen, only sound
common problem with LCD TV is a dead screen but there is a sound. so the problem is always coming from inverter board inside the lcd, inverter board controls the ccfl bulbs that illuminate the image in the screen. there are 4 or more bulbs inside your screen supplied by inverter board. you can see this inside at the back of the screen there are 4 boards inside, display driver board,power supply board ,inverter board and input board, this could be repaired or replace.but you need some tools for opening the case and test equipment. add comment if you want some help.. hope i help you.... thanks.....
Aug 31, 2011 | AOMNI Corporation Magnavox 20MF500T/17 20...
My LG 21 int ch flat screen takes time to show pictures,the red button appears on and sound will be heard but their will be no pictures,they appear after some time please help me.
hi,
You have to check the back light of your lcd TV. All lcd screen have a back light to illuminate the pixels. you can conform is the back light is faulty or not by watching the lcd screen nearby. Watch can you see any image (negative image) on the screen. you have to look very closely. if you see any image on the screen then the back light or the back light inverter is faulty.
first of all check all the electrolytic capacitors in the power supply and back light inverter board.If available then replace these capacitors first.
You have to check the back light inverter board. Normally in lcd monitors you can see three circuit boards. power supply, mother board, and the inverter board. If available then try to replace the inverter board. There are high voltage transformers in this board. There is a chance for its winding get short. You will not get the transformer in open market. Try for the inverter board .
ok
Jun 09, 2011 | LG 37LD450 37 in. TV
My Westinghouse SK-32H540S pictures shuts off after 10 seconds. the sound stays on but no picture. is it the troubleshoot? i tried unpluging everything and repluging it and still the same thing happens...
This problems are the tv 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards provide the tv LCD screen pannel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
My compaq presarion c-500,it is showing power on but display is not showing on.
Try an external monitor & see if it will work. If it does, then this might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 29, 2010 | Computers & Internet
Bravia kdl-40s4100 has no sound, no picture. Checked the line fuse to the HV power supply and it checked good. PS problem? Where can I find a replacement circuit board or would I be better off replacing...
The 2 long boards call the LCD inverter boards are dead.These 2 long LCD inverter boards are dead,must be replaced.These 2 long LCD inverter boards help the LCD screen to have a backlight to have a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jul 14, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
White screen only, can hear sound
The wire from the main video board to the LCD screen goes bad after a while. I don't know where to find a replacement?
May 20, 2009 | Westinghouse SK-19H210S Television
Televison & Video Logo
23 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
