I bought this unit 3 years ago and never used it. I took it out and plugged it in and it won't come on. I tried to push the clear and power button at the same time, no help. Any ideas?
I bought this model 2 years ago.it broke in one vear .I took it back to walmart they replaced it .now one year later it is broken again.It is made cheap .no way to fix mine. steer clear of ge products unless you want to buy a new one every year.
i would make sure batteries are good an with the batteries out look inside compartment and see if there any rust down where the batteries go if so try to scrape them clean
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Carburetors could be dirty/blocked. Open throttle and spray carburetor cleaner in them, wait a few minutes, then start. Also spray carburetor cleaner again when revving. Should fix it.
Also, try starting with no choke and no throttle. It could be flooding.
Clean spark plugs.
My Samsung camera SL105 won't turn on. When I push the power button the lens tries to extend out but won't. Then it beeps and goes back in. What is this from. I got it to open a couple times today but back to same now.
Looks like your screen going to 'kaput' already.....anyway try to reseat the memory modules 1st. If u had the luck..it may works that way.....good luck
