Question about Toshiba 32AV502R LCD TV
Blinking light The tv automatically turned off now it wont turn on constant green flashing light
    Top Expert:
  • Toshiba Master
  • 54,817 Answers
Probable power supply failure.
Posted on Jan 12, 2014
6ya staff
SOURCE:
ginko
Ginko
  • 19396 Answers
SOURCE: i have 3 blinking lights and tv wont turn on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Anonymous
  • 7 Answers
SOURCE: tv will not turn on. timer light constantly blinks
If you can get into the main menu go to load factory default and reboot, This will reload factory settings and this operation will erase all unwanted settings and load back to factory default. so you can load your own settings and take back control of your tv.
Posted on Feb 23, 2010
Chi Chu
  • 8457 Answers
SOURCE: 42" Toshiba Plasma TV wonn't turn on
Power board require changing.It dead.
Posted on Jan 08, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: wont turn on
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Jul 31, 2010
Your main power board located in the center where your power cord will plug into is going bad, actually it's just a relay. I have the same problem, tv works for hours til relay overheats, then tv shuts off and tries to restart, hence the clicking and the 3 green flashes, mine will actually restart after 15-30 minutes. search online for the board, ranges anywhere from 150-280. I haven't found anyone to sell just the relay. I am trying tv with rear panel removed and cover removed from relay to see if relay will not malfunction? Board is a simple plug and play, just remember to have the tv unplugged.... you can actually remove the rear panel while on it's stand, just don't remove the screws holding the base onto the tv.
Posted on Nov 18, 2011
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Hi, I have i Sony wega tv when i turn it on green and red lights flashes and nothing happens please help
The red light is key to your issue---is it blinking in a sequence--constant blink or for example 3 blinks, pause and 3 blinks?
Mar 20, 2012 | Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
GREEN LIGHT COMES ON BUT TV WONT LIGHT UP AND WONT TURN OFF
Call the number on your TV manule and tell them you probley have a Loos Fuse in your Tv
Jan 05, 2010 | Apex Digital LD1919 19 in. LCD TV
Tv wont turn on
The green light flashing indicates an error code, plasma tv's cannot be repaired at home without the right equipment and service manual, the fault could be power supply, processor or virtually anything, what technicians look for is the frequency of the blinking and the time between sets of blinks, this normally gives the tech a code that enables them to go to the right area, the only thing anyone can tell you is that the processor is probably ok, you really need to get a quote or count the blinking and the timing eg: "blink blink short pause blink), and repost the fault, then we can possibly tell you where to look...Phil
May 18, 2009 | Akai PDP4206EM Television
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Timer light flashing
The capacitors wont always show any outward signs of being bad. But it the LED blinks constantly without stopping thats telling you the DM isnt completeing the boot sequence. So most likely the capacitors are bad. But dont put the same ratings back. go with 1000ufs @25V but make certain they are the 105 degree celcius capacitors. If you need further assistance let me know
Jun 17, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Toshiba 32AV502R LCD TV Logo
194 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
