Pontus PAC7002 CD Player Logo
Anonymous Posted on May 27, 2009
Confused about wires for car stereo installation
I have an alpine cva-1004 with the 6.5". Now it has the blue/white wire for the remote to the amp and im sure thats what that wire is for. Now there is another wire which is brown/white and it has a label that reads remote out. I am unsure where i am to connect this wire to? any help would be appreciated.
Anonymous
Level 2:
  • Expert 37 Answers
  • Posted on May 27, 2009
Anonymous
Expert
Level 2:
Answers
37
Questions
0
Helped
20243
Points
119
This is to be used if you wanted the Alpine to control the on/ off functions of other audio devices (such as a second amplifier)
Anonymous
Level 2:
Scholar:
  • Expert 96 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
96
Questions
Helped
40628
Points
294
The blue/white wire is actually for the power antenna. They included the remote out for aftermarket devices
2helpful
I need the wiring diagram to install a Alpine 7516 in a Dodge Colt 1994.Thanks! Alain
1994 Dodge Colt Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Red/Black
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/White
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/Green
The manual for the Alpine 7516 can be purchased here:
https://www.samswebsite.com/en/photofact/search/index/model/7516
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
2answers
Need help bypassin parkin brake wire
you need to hook up the foot brake like it said but hook up a switch on the parking brake wire to ground do not hook it up to parking brake just a switch ground one side ant togle it while your foot is on the brake once the screen is on leave the switch in that position you will have to do this every time you turn the car off but you can see the screen while driving
1helpful
Alpine cva-1004 no audio video ok
Many aftermarket car stereo has to output trigger wires, one antenna and one amplifier. Antenna trigger only works in radio mode for the power antenna to operate. Amplifier wire operates in any mode the stereo is in. Check to make sure you hooked up the correct blue wire to your amplifer.
Bob
1helpful
Ipod input?
I've got an Alpine CVA1004 and use my ipod on the aux input of the headunit. The alpine-ipod interface was too confusing for me, with the ipod connected to the aux input, I just control the music from the Ipod, I find it easier that way.
How to bypass alpine cva-1004 to play while driving
Doing so is very dangerous.
I admit it is an annoyance because some basic features you can't even control while driving.
Once again I would really suggest not bypassing the saftey feature.
If you still wan't to go threw with it there's 2 different ways. One of which is applying the e-brake ever so slightly so that the brake light comes on on your dash but could also wear out your e-brake over time doing this. The other is permanently grounding the e-brake wire that comes from the cva-1004. You must cut the wire and ground it (on the cva-1004 side of the cut wire) and insulate the other side of the wire you cut so that it dosen't interfere with the normal operation of the brake light.
Rember..... When you have an accident you were warned!
No sound from front speakers during CD operation.
I think you are using an external amplifier,if this is the case,you may be using the wrong remote wire for the amp.
Alpine use two blue wires,BLUE (only) this wire is for the pwr antenna and every time you insert a cd, this pwr line cut out.
BLUE/WHITE STRIPE this is the remote wire that you need to connect the remote of the amplifier.
thanks for rating
Alpine cva 1004 r head unit
make sure the handbrake wire is attached to a gd ground or it won,t allow you into the menu because it thinks its unsafe while the ignition is turned on !
its a yellow/blue striped wire that needs to be earthed !
2answers
Alpine mrp-m450 Amp won't stay on
im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
2answers
Alpine CVA-1004
lol i had the exact problem that you are having with my alpine. The solution is taking the blue cord that was inside the vehicle (forgot what cord it was) and actually connecting it with the other blue cord thats different makes the factory amp read the cd player and ta-da it works. crazy isn't it
Top Pontus Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Pontus Car Audio and Video Expert? Answer questions, earn points and help others
