Question about Sony 32CX520 BRAVIA Multisystem LCD TV for 110-240 volts
SONY Bravia NX710 TV Screen or Color Problem..
    Champion:
  • Sony Expert
  • 212 Answers
Now a days most common problem is this in Sony led please replace common mode coils which are very near to Lvds jack these collies are situated between system ic & led tcon & are responcible for communication between these two
Posted on Jan 12, 2014
4 Suggested Answers
6ya staff
SOURCE:
adnahsl
SOURCE: "Guide" button makes Sony Bravia TV go to black screen
I am having the same problem with my newish Sony Bravia. There is only a black screen when I use the "GUIDE" button. And individual channels show "No program description".
Did you ever figure out the problem?
Thanks.
Posted on Jan 05, 2011
tvtek
Don
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
Anonymous
  • 84 Answers
SOURCE: Sony Bravia XBR4 52inch LCD cracked
It can be replaced, but it is probably going to cost you more then the cost of a new TV to do it.
Read the tech tip I wrote on this very subject.
http://www.fixya.com/support/r3831376-when_cracked_lcd_led_or_plasma_tv
Posted on Jan 07, 2010
Bravia kdl-32l5000. Why does it have a red screen?
Color circuits are messed up and need repair.
Mar 05, 2016 | Sony Televison & Video
Bravia problems sony tv
Just visit the site given below. It has screen shots to defective Sony Bravia. Compare it to that of your TVs' and make sure about the fault. In most cases, the fault you described here sill be repairable.
Nov 20, 2013 | Televison & Video
Bottom half of Sony Bravia TV screen has color distortion
Check for loose contacts in power outlet, RC cable, jack and socket.
In order to ensure, it is not caused by the input device, connect a DVD player and see.
Aug 22, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My sony bravia screen turned green I do I fix it?
When the color of the screen is complete green, you should not worry. That is the normal color that should be on the screen when no program is coming in because the cable box is off. So simply press OK on the remote of your digital box and your will see picture on your TV. If none appeared, then there is problem on your cable box. Call then your service provider.
Nov 29, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony bravia kdl 32l4000 - color bars running vertically on screen
Dec 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
A thin blue line has appeared on my sony bravia tv screen
The screen is delamminated take it back and get a new one
Nov 02, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Colored bars on Sony Bravia LCD Digital Color TV Screen
This is a screen tab fault and in most cases will require the screen replacing
Sep 13, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
I just bought Sony Bravia flat screen television set today. The images on the screen are 90% greenish in color. How do I set it right to the right human color ? Please help ASAP or I will return the TV set...
go into menu, look for picture or setup mode. in setup look for chroma/color & tint/tone controls. you should be able to adjust to personal preferences. one other setting, is the color temp setting. this will allow you to change to warmer back wash. hope this helps because the Bravia is a good set
Sep 14, 2009 | Sony BRAVIA KDL52XBR2 Television
Sony bravia LCD KDL52 TV: blurred picture with color bands
It is most likely the TCON board (located at the top right against the LCD panel). When these boards have problems, they can act up when cold or warmed up.
You will want to check with any extended warranty company you might have, or Sony's part website for the availability of the TCON board.
The problem here is, sometimes those TCONs are not made available separately and need to be replaced with the screen.
If you have to replace the panel, buy a new tv. You'll save yourself a costly repair.
Jul 14, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
Sony 32CX520 BRAVIA Multisystem LCD TV for 110-240 volts Logo
110 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
