How do I get my Kenmore oven unlocked after self cleaning mode? It has been locked since the self cleaning has since ended over 10 hrs ago. I tried hitting cancel many times and unplugging it for a few minutes
I had the same problem today. After I cleaned my self cleaning oven the cycle went back to normal but the oven door would not open even though the screen was clear and didn't read locked. I held the stop button for 3 second, I don't remember what the message said on the screen but I held the stop button in again for 3 seconds and the screen said locked then I did it again and the screen said door and the oven opened. I don't know, maybe it was just sheer luck it's worth a try. I'm happy.
This worked for me too! I'm not sure if it was from hitting "Stop/Time" button or the "Clear" button... but through a series of hitting them (for 3 seconde or more) it worked! Thanks to all!
Gene Argabright - worked for me by pressing stop button for 3 to 4
Try putting it back into clean mode and and listen for the lock motor to start turning. If you can hear it, keep trying the door until it opens. Don't hold steady pressure on the latch, just pull a little then let off. After you get it open, hold in on the door switch and cancel the clean mode and it should go back to correct position. If this doesn't work, you may have a failed door latch, control, temp sensor, or switch. Post back with the complete model number and I will look it up and see which latch assembly you have and see if we can get it unlocked manually.
I am unable to find any information on the model number, there may be three smaller digits in front of the number, but if it is like the one in the picture you have it listed under, you can't see them until we get the door open. If it is like the one in the picture, a single wall mount oven, The oven will have to be removed from the cabinet and the top removed to access the lock motor on the top of the oven liner. Then the latch assembly can be checked or removed so that the door can be opened.
I was able to track down the model number on my work computer today.(I have a larger database on it) It should be a 66595781000, this is a freestanding Kenmore range built by Whirlpool. If this is what you have, Pull the stove out Unplug the stove Remove the back from the stove At the top of the rear of the stove you will see the lock motor Try to turn the motor manually to unlock the door If you cant turn the motor, remove it and unhook the rod that goes to the front of the stove. This rod is connected to the latch that holds the door closed. You should be able to unlock it that way. Go to sears.com, go to parts and enter the model I listed. Click on chassis and you will see the parts breakdown. Sorry I wasn't as much help over the weekend, but having it listed under wall oven had me thrown. Post back if we need to go through the checks of the lock system or if the oven won't operate in bake after you get it unlocked.
Thanks for the help you saved me a costly repair bill!!!
I was easily able to rotate the rod on the motor freeing the door. My only hint to the repair, my stove had a ton of screws to remove the motor was behind the top back panel of the stove so no need to remove all those screws. I doubt my clean will work again, but at least the error code went away and now my family can use the oven again!!!
Hey Michael, my model number is 790.75711893 and I can't get the oven door open... I tried hard reset (uplugged for 5 minutes) and pressing the clear button for various seconds... nothing has worked. Thanks for your help, Ric
press stop button for 3 to 4 seconds and it will opem..
After inadvertently pushing the wrong button late last night
(caz' I noticed the oven light was on)
I was having the same problem with the door locking and not unlocking. I tried what I read posted here to no avail. However,I ended up fixing the problem (just now) by simply "holding down" the "Stop/Clear" button for a few extra seconds and wallah!
SUCCESS!!! :)
Sincerely...~DanSin^v^
Just Toasted: Mod 790 45792.101. Just fixed the problem.
Pulled the unit out from the counter-top. Opened up the rear panel protective cover. With power off, I disconnected one side of the motor limit switch. Powered up again and started the clean cycle. The motor advanced the lock 1/2 turn. Powered down again, reconnected the limit switch and powered up again. This time, the motor advanced the lock to the full up-right or unlocked position. The trouble light went off and everything works normally.
I had called Sears for help, earlier this week. After talking to numerous people about it, my only options were:
1. Did I have a warranty?
2. Did I want to purchase an extended warranty?
3. Did I want to schedule a service call?
When I asked for a supervisor, he asked for my telephone number and advised me they had no record of me. I said the builder had the range installed and I did not have anything but the user manual.
He re-explained the above options and said :
If I wanted none of the above, he could not talk and would not talk to me.
Now that's real Sears customer service for you.
I told him I would tell a few people about the service policy, and would not buy a Sear appliance again. Thanks.
Flemingxyz had the correct solution for my problem. I have a wall oven version and holding down the clean button as described resulted in the door coming open.
Thank heavens for this forum.......
I have a kenmore oven I put the oven in lock and placed it on clean. held the clean button down for 3 secs when i was done and returned the lever to the unlocked position and when I went to open the oven
it comes out about and inch and is locked.
Is there any tricks to getting it open with out taking it apart.
[email protected]
If you have this problem again or before you use the clean cycle again do the following. Turn off the cicuit breaker to the oven, remove bottom drawer, unplug the power cord, open the oven door, try pulling up the oven top; (there may be screws holding down the oven top). observe the locking mechanism, the plate the latch is attached to will sometimes catch on the arm that actuates the latch. Bend the plate down making sure the latch will not hit the top of the door opening. This should solve the problem. When the arm is caught on the edge of the plate the latch will hang in the closed or mid position. With the power off and the power cord unplugged you can also remove the back cover, (there may be a top and bottom cover), remove the top cover first. Remove the screw from the arm thats attached to the locking motor (you will is the arm extending from the front of the stove to the motor). Actuate the locking mechanism by pulling on the arm to see if it will move without any obstruction. As long as the locking motor and or oven control module is not defective (since the stove is new this should not be the case) this shuold be all that is needed. In the future be carefull not to accidentally push down on the locking latch because this will cause the arm to drop downward and catch on the plate again.
Look...all you do is remove the back panel. It takes 2 minutes. you'll see the pulley on the upper left. turn it. check to see if the door is unlocked. Done!
Exactly same problem!!! Display shows E1 -F5-. - Couldn't get it to go back into lock mode (as suggested). Can't find model number on oven, but user guide lists several: 665.920xx (10 variants 02-25), 665.950xx (11 variants 02-29), and 665.958xx (5 variants 22-29) Thanks
hey i do nt have the same exact oven as shown in the picture. but i am having the same exact problem and it is a kenmore oven. what can i do to fix it?
My Kenmore oven door has locked and nothing seems to unlock itI tried clearing it, tried to turn it on the cleaning, this stove is only a little over a year old.;
Kenmore model 790 45792.101 Accidentally pressed the clean button instead of the broil button, then up-arrow to start broiling, with the oven door slightly open. The unit started the clean process by attempting to lock the door, with it open. Now the door lock is in locked mode and the function buttons don't work. Tried the "hold cancel" for three seconds, powered down for a day, it comes back up in same locked mode. Re-set the time then tried starting and stopping clean cycle. That doesn't start the cycle. Occasional F9 shows on the display, then it changes to the time. If the Cancel button is held down it changes to "dor".
Yes; how can I unlock my oven after it self cleaned?
I locked my Kenmore oven to start the cleaning process .it scared my teenager .He turned it off and I can't get it open since.
Tanya G
would'nt start the cleaning progess the lock kept clicking turned it off . tried again and it locked and I can not opan the oven
I accidently pushed the clean button instead of the clear button. now my oven door is open and the locking machinism is jammed so it won't let me shut the oven door,, I unplugged it several times and left it for over an hour and even have hit the clear button several times to no avail// please help
Our Maytag Stove/oven combination (Model MER5550AAW Serial 14212746UU) has been locked since last Wednesday. We did the self clean and it finished the cycle but now still has the light on for LOCKED and won't open. We tried to cancel, we unplugged it, and even were able to push the lever over that holds the door shut. But, it says locked when we can open the door and lock goes away when it is in the locked position. How do we fix it?? Please email [email protected].
Thank you.l
I have a dual-fuel kenmore elite range 790-75503206. There was a power failure, and when I went to set the clock (without my glasses) I accidentally hit "clean" and the oven door locked. I tried turning the power off , to reboot it, but that didn't work. I read the postings on this site, and when we had another power outage last night, I tried the procedure suggested, ie: set the clock, then turned on "clean", set the timer for the clean cycle, and when the fan and motor engaged for the clean cycle, I pushed "Off/Clear" and yippee, when the clean cycle noise turned off, the oven door was OPEN. Oh Joy.
how long does it take to clean the oven after i lock it? It's been cleaning for about 2 1/2 hours and it is still on. It wont unlock.
I accidently pushed the clean button instead of the clear button. now my oven door is open and the locking machinism is jammed so it won't let me shut the oven door. I unplugged it several times and left it for over an hour and even have hit the clear button several times to no avail// please help
I have an older model Kenmore self cleaning stove (1986) and after cleaning, I can't unlock it. The locking handle won't release and the lock light is on.I tried turning off both the selector and the oven temp knobs and putting the selector back on the lock/unlock setting. What can I do to get it to unlock? I'm not sure of the model number. Thanks.
I hit the self clean button instead of clear on my Kenmore electric range 790.9621 now the door is locked but it is open and I cannot close
Kemore range double oven is locked how do I unlock it?
Model # 66578003801
I have kind of the same problem. My wife set the oven for self cleaning. About an hour into the cleaning cycle I heard a loud bang. I went in the kitchen and noticed there was nothing displayed on the digital display. I then tried to push the buttons but nothing worked. The only that does work is the stove top burners, the oven door is still locked and the display is dead. This is a Kenmore 665.95012102
I have kind of the same problem. My wife set the oven for self cleaning and after the cleaning cycle the door wouldn't release and door locked is displayed on the digital display. I then tried to push the buttons but nothing worked. The only ones that work are for the microwave in the in wall model of my Kenmore oven. This is a Kenmore that is "only" about seven years old. How do I get the door to unluck and do I need to replace the locking mechanism? My wife is "threatening" to call the repairman and I've already tried holding the light button and restarting the clean cycle. Yikes!!!!
kenmore self cleaning oven wont shut off
How to use the self clean
How to use the option self clean on oven
Worked for me also held stop buttone for 3 to 4 sec's and it opened.
