SOURCE: Front bottom leak from my LG TROMM HE Washer
please rate my suggestion...
SOURCE: rubber gasket removal LG Tromm front loader
We found there is three small holes on the seal right inside the door, check to see if they are clogged with soap scum and clean them out. Run a cycle of hot water and bleach. Then, after each use, leave the door open and let it air dry and this has seem to work.
SOURCE: the door gasket on my
I use nylon cable (zip) ties to clean them. (Not sharp, so no danger of poking holes in the gasket) You may want to run a washer cleaner through the machine occasionally, such as Affresh or Washer Magic, or one made by Tide or Clorox.
