Black cartridge needed replacement; when I installed the new black cartridge, it still showed INK DEPLETED, the cyan then also registered as INK DEPLETED, and no other printer function works - I can't print test page or enter the maintenance menus. Do I need to replace BOTH cartridges now? Same problem
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
