All fuses good,no voltage on main power board,no relays clicking,no light on front,no stand by voltages present
SOURCE: Toshiba 37HLX95 wont power on, just click sound
I have the same problem. It happened once before about 4 years ago just after I bought it. I put a DVD in without the power on. I was able to take it out and it worked fine. This time my daughter put the DVD in, I took it out but still no picture or sound.
Have you had any luck?
SOURCE: Toshiba 26lv610u tv/dvd has no sound or picture
Yes if there is no clicking, then the power supply is usually faulty. However its difficult to tell if it has affected any other boards(like the main board) with out testing it. I would suggest that you take the assistance of a tech, have him test it to determine if its just power. If yes then you can get a new power board and replace it. Otherwise it may be wiser just to get a new tv. You can get a 26 inch tv for around 350-400$ now.
SOURCE: my toshiba 50hpx95 plasma tv makes just a clicking
A common problem with modern power supplies is dryed out capacitors in the power supply, This pulls down the voltage and shuts down the tv. The can usually be spotted if you know what to look for (they swell up and deform a little). It is not a job for the novice. But capacitors are cheap.
Try a local tv shop for estimate
pete
Hi Timothy Sarris, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
