Tablets & eReaders Logo
Neida Reese Posted on Jan 13, 2014
My I pad air won't start up after charge
I charged my I pad air now it wont start up
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 11, 2014
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
366
Points
Double check to make sure your plug is in the wall outlet, and that you don't have a controlling wall switch off. this happens a lot in the car too, my charger has to be rotated to get the cigarette lighter connection just right.
Important tips to fix the problem of Kindle Fire won't turn on?
Press and holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, you can try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to make the Kindle Fire work again.Oct. 11, 2014
SOLVED: My kindle won't turn on. Is it the battery? - Kindle ...
How to Fix a Kindle Fire That Won't Turn On - Lifewire
www.lifewire.com > kindle-fire-wont-turn-on-or-charg...
May 26, 2020 - Perform a soft reset. A soft reset resolves many common issues without affecting any data on the device. Press and hold the Power button for 40 seconds, then release. The charge indicator light should turn on after several seconds, and then the Kindle Fire should reboot.
Amazon Fire Won't Start - Technipages
www.technipages.com > amazon-fire-wont-start
Fix an Amazon Fire that Won't Start. Hold Power Button. Ensure that you are holding down the "Power" button for at least 5 seconds to power it on normally. Charge Using AC Adapter. Ensure that the Amazon Fire has a charged battery. Hold "Volume Down" While Powering On. Restore Latest Software.
VIDEOS
https://www.google.com/search?q=Kindle+Fire+won%27t+turn+on
2answers
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Reset Kindle Fire When it Won Turn on or Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
1helpful
2answers
My tesoar tablet showed charging for 3 seconds then that was it now it wont turn on it wont do anything
I have a hacker inside my Samsung galaxy 8 notebook, he controls my ph and I pad, how do I break the tracking link.
5helpful
2answers
How to reset kurio tablet? Won't turn on at all
my kurio tablet wont turn on, i have tried charging it and turning it on , and answers on google
Top Microsoft Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
