Question about Canon PowerShot A300 Digital Camera
When I open the lens... A menu page comes up...
Instead of the a picture view the Lens is seeing... This started two weeks ago.. What have I've done?  What do I do to correct this?
Thanks,
John
Gainesville, GA.
  • Anonymous Nov 16, 2007
    Thanks
    It was an imager problem and under a special warranty... Cannon offered to fix it or exchange it for a Refurbished A530.. Customer Care said it was never used by retail but was an over run or demo internally... I paid the $75 + Tax and shipping.... I love the new camera!!!!
    Thanks for your help!
  • Canon Master
  • 4,738 Answers
If you're seeing black or distorted images both on the LCD and on the recorded pictures, then this might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info: http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 16, 2007
6ya staff
SOURCE:
Water Damage Lens Error
Most cameras with retractable lenses are very sensitive to grit (sand, dirt, salt etc.) in the lens mechanics and will shut themselves off if everything is not perfect. It's possible some salty water remained in the works and left a salty residue when it dried out.
Unfortunately, most repair shops will charge you almost what the camera is worth to properly clean it and it is not a job for the do-it-yourselfer.
Apr 27, 2017 | Canon SD4000 IS IXUS 300 HS Digital Camera
My aperture or lens isn't opening - can't take a picture. It worked fine a couple of weeks ago and when I tried to use it this week it was a no go.
Aperture and lens are two different things. If you mean the camera is taking black pictures (something common for the S5), then see this link.
But if you mean that the lens isn't extending properly, then see this video:
Dec 08, 2012 | Canon PowerShot S5 IS Digital Camera
The screen wont come up so i can see what im taking a picture of how can i fix this?
If you can see the menus and review pictures you've already taken then there's apparently nothing to fix. You have to use the viewfinder to compose your pictures, not the LCD on the back. The live view capability to use the LCD was introduced with later models.
Aug 03, 2012 | Canon Digital Rebel / EOS-300D Digital...
I have a Fuji finepix j38 that is appox. 8 months old. When I turn the camera on, the lens comes out, immediately retracts, and "zoom error" comes up on the LCD. I can view pictures, but can't take any. ...
I thimk your problem is that you have sand betwin the lens mechanism and that cause the immediately retract.you can try to apply air pressure near the lens but with care
Oct 05, 2010 | Fuji Cameras
Kodak M340 lens extends then retracts immediately
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Sep 10, 2009 | Kodak EASYSHARE M340 Digital Camera
Lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
Aug 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
Zoom lens won't come out
If the lens will not come out, i need you to try this steps first before sending it in for SVC.
Improper battery connection might be the reason why there is not enough power for the lens to come out and open.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just set the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
About the warranty, basically you do have a 1-year Limited Manufacturer's warranty and it will start from the date of purchase. And if that expires, there is a usual charge of about $50-60. You'll be seeing the payment upon the creation of the online service request through www.samsungcamerausa.com and just click on Customer Service then Option 2.
Hope this works.
Dec 31, 2007 | Samsung Digimax S630 Digital Camera
No power and lens will not come out
Your lens mechanism is jammed or off its "track" you need to get it realigned and lubricated w/a safe lube, like a white grease. You can try and gently "help" it out while it is trying to do this mechanically and if you hear a little ckick, then it may have realigned itself. Some have used compressed air to blow out any crud in there. Try these or take it to a camera shop. maybe they can help instead of sending it back for service as there is usually a fixed fee for ANY repair, big or small and usually eclipses the cost of a replacement camera, or very close to it.
Dec 28, 2007 | Canon PowerShot S3 IS Digital Camera
Pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Aug 26, 2007 | Olympus FE-170 Digital Camera
Black Screen
camera ccd is / has failed - also possible , lens iris is stuck closed ( on monitor , can see very faint snow noise against black background - check if iris opens , by shining penlight into lens );
May 03, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Canon PowerShot A300 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
