SOURCE: my pentax k100d has a memory card error
Trun the camera off and remove the batteries. Leave it for at least a minute before inserting the batteries. Put the car in and turn the camera on.
The firmware in these cameras can get confused. Removing the batteries for a minuite or two will allow the camera circuits to discharge and so it will reset from start when powered-up again.
If this does not work then the camera may need to be sent away for repair. This need not be expensive it could be as simple as re-programming the camera. (Their program memory is writeable and so it can be accidentally altered under certian circunstsances. It may be possible to do this yourself using the downloadable firmware upgrade, but I would let someone else try thet first!)
However, it is just possible that the new card is also faulty!
Check the cards in your PC by obtaining a SD card reader to allow you to plug it directly into your PC.
For reference I would always recommend inserting and removing memory cards with the camera turned off. I would also use the SD card reader to load the images into the PC. Unplugging devices form the USB port can be harmful to some devices. Check the bottom right of your PC screen for an 'safe unplug' icon when things are plugged in.
SOURCE: Kodak 4 GB SD card (brand new) shows "card error" in Pentax optio
Hey,
The problem is your camera doesn't work with the 4gb card, its too big. Sorry!
Your stuck with 2gb cards. Id suggest to echange the card to two 2gb cards.
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: memory card
Hi and welcome to FixYa.
Your camera will not work with an SDHC card. It must be an SD card.
Don't forget to format the card in the camera after you install it. Elsewise it won't work properly.
Thanks for coming to FixYa, and feel free to rate my solution.
Rob
SOURCE: Memory Card Error on 4 Gb CF cards (80x) for Pentax Optio 430
The maximum supported memory for Pentax Optio 430 is 256mb and for Pentax Optio 430 RS is 512mb.
Check this site for more information.
Optio 430
http://www.upgradecomputermemory.com/ram.cfm//memory/P/Pentax/Pentax-Optio-430/
Optio 430 RS
http://www.upgradecomputermemory.com/ram.cfm/memory/P/Pentax/Pentax-Optio-430RS/
