We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
The freezer is probably in need of defrosting. This usually occurs when the freezer has been over packed. It needs to be able to ahve air flow through it, there are holes in the back of the freezer and a defrosting element at the top and they need to be clear in order to keep it frost free. It happend to me and we called an engineer out. solved it by using hair dryer to defrost it.
Normal
0
If the bottom of the freezer is freezing (but only just), but the top is just above freezing, then your problem may be either your defrost timer or the defrost heating element. You'll need a thermometer to determine how cold (or not cold) your freezer is getting. Usually a freezer is happiest when it's full, so being too full is likely NOT the problem (there is room for air to circulate, right?).
If
you're handy, you can troubleshoot the problem yourself by following the
suggestions found here, as that may at least identify the problem. Replacing components inside your refrigerator isn't incredibly complicated, but if you're uncomfortable with taking things apart, you may be better off seeking the help of a properly trained professional.
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
If this is a frost free model the fan could be bad. If not frost free it is probably low on freon. I don't recomment fixing this as you can never really trust the freezer again. Most of the time the leak can't be found and adding freon is only a temp solution.
