There is a fan in the freezer compartment that blows cold air into the refrigerator part. If it is not working or if the baffle that directs the air is not functioning, that could account for the less than ideal temps.
Also check the auto defrost mechanism for proper operation.
When the top half of a freezer is not working properly it is a sign that the air circulation within the freezer is not functioning. In other words, the freezer refrigerant is still working properly, but the cold air it produces isn't going anywhere: Instead, it is sinking to the bottom of the freezer (heat rises) where it does an excellent job of keeping that half of the freezer cold while missing the top section entirely.
The air circulation problem is usually caused by a fan issue. Find where your fan connects to the refrigerant system and pumps the air out into the freezer. If the fan blades are stuck or frozen, you may be able to loosen them or replace the fan. If the fan works mechanically but does not turn on the problem lies with the motor instead. In this case, you can replace the motor or call a professional it may also be fan or evaporator
Hi
Normally what causes the refrigerator/lower chest not to be cold enough is that the fan that pulls the air from the freezer is not working. Check to make sure it is working, if not then you will have to replace it. If it is working then check you defrost timer, it could be faulty. I will include these two websites for parts.
partselect.com/ appliancepartspros.com/index.aspx Please take time to rate me Bud
Try to defrost the freezer and see if the air valve opens and closes properly if all of that works then there is a problem with the fan that moves the cold air into the refirgerator
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
There is a fan behind the back wall of the freezer about 1/2 way up from the bottom, you should be able to hear this running when the freezer is on. If you do not hear this then you need a new evaporator fan motor.
If you hear the fan run then you most likely have a problem with the automatic defrost cycle that would most likely be the heat element that is located just below the coils inside the freezer behind the panel.
The evaporator coil must be lightly frosted from the top to bottom. This proves that all of the r-134a freon is still present in the system. If you visiblely see that it is not (half frosted the other half warm?no frost) then this is a sign that the r-134a freon has leaked out. Another way to determine for sure is to use refrigeration gauges to check the pressure.
let me know what you found then we can take it from there... hope this was helpful
If it has a fan in the freezer it need to be running to circulate the cold air.
If the coils are not icing up evenly from top to bottom you have a system low on freon.
The light frosting is normal.
A model number would really help to troubleshoot the problem.
