I need to boot my pc using a perfectly good working flash drive, data is confirmed on the flash drive but when I f12 to change the boot drive it dosen't show up.....but can be used in windows....very starage...I just need to boot this pc using a pci port, confirmed working, as a boot device to formate the drive and install a new system...all win7...please help!!
SOURCE: can not get online because of missing drivers for ethernet
do windows update custum scan least get driver for erther net on a cd from anther ok the custum scan then hardware add all
SOURCE: Device will work faster on USB 2.0 pop-up message occurs when USB Device is plugged in
That means that the USB drive that you have on your computer is either on the USB 1.1 driver and you have to update it or your computers USB is not capable of USB 2.0 speed. First thing you need to do is find out the model number and brand of your motherboard. Then go to the manufacturers website then look at the manual for the board to find out if you have USB 1.1 or USB 2.0. If you have USB 2.0 then download the latest drivers for your board. If you only have USB 1.1 then your only options is to buy a USB 2.0 to PCI card that will give you USB 2.0 or just stay with the USB 1.1
SOURCE: How to reset your lost windows password using a CD/DVD or usb fla
As far as I know there a are a lot of ways to solve your problem and the easiest one of them is to use program designed to see to such problem!
And I have tried many of them, according to my experience, I recommend you the password recovery bundle which not only can recovery your windows password but also other files' password.
And I google the address for you. it is http://www.recoverlostpassword.com/products/passwordrecovery.html
Wish you good luck.
SOURCE: TSSTcorp CDDVDW TS-H. DVD works
use win2flash and dump the Win 7 install dvd onto a usb flash drive and install from it
http://wintoflash.com/home/en/
Hi Edward Squires, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Is your flash drive really PCI, or USB?
Does motherboard BIOS/UEFI have USB port?
After examining the issue I found out I was hacked badly .... The PC had no administrative users, including myself both admin and owner/special rights .... But he was good, my windows was trashed/unrecoverable and my external backup drive a reformat fixed that, of course he gave "himself" all rights to my stuff.... I even cough him in user's, while working with permissions, he would be there, in the root and all over the place... A IP address in black with a red ? mark, at the start, when I tried to capture it, it turned to a unknown user group with all rights and couldn't be changed... So I went and got a box from Micro center, bare bones just Windows 7 Ultimate, and built it up with what I need and use, only no extra software was installed ........ Now I have the BEST PC I have ever had, just 53.5 GB used, and runs super fast...... it cost me $219.00 to fix .... Thanks to MC . A Note: To keep the hacker out, I unplugged my modem/router Xfinity box to change the dynamic IP address. Next I buy another box, the same, and set it up, her's " the wife's" was corrupted worse them mine from the same guy! Thanks for all the responses, it helped me get to the root of the problem...
