2000 Nissan Sentra Logo
Posted on May 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car wont start
The car wont start when turing the key it makes the motor wont start some say it can be the fuel injector some say its the starter some say its the projection sensor
Anonymous
Level 2:
  • Expert 112 Answers
  • Posted on May 27, 2009
Anonymous
Expert
Level 2:
Answers
112
Questions
11
Helped
49320
Points
311
Check if u have spark , if u do have spark and hear a clicking noise its possibly your starter
2answers
Van wont start, and i replace the starter. you can hear the fuel pump when you turn the key, and it has sparks
Just because you hear the fuel pump run does not mean you have correct pressure at the injectors. Use test gauge to make sure. Have you run compression test to make sure timing belt has not broken?
1helpful
Turn key on gauges move but wont start noting on key but tilt and trim works
How long since a tune-up?
Are there any applicable trouble codes?
Are you saying it cranks good but won't start or the starter motor won't even crank? If the problem is the latter, have to make sure battery has a full charge, battery connections all good. Then check voltage and ground circuits for the starter motor. Any testing at the starter, make sure tranny is in park or neutral and functional parking brake is set. Safety is your responsibility.
Of course if it cranks good but won't start, that is another issue. Usually with gasoline engine, check spark--proper fuel pressure and fuel injector pulse. Also, you may need to check cylinder compression.
What is year--make--model?
2answers
When starting car sounds like battery was dying then did not start got a jump and started drive home turn off car and nothing no start. Got a new battery still new start got new altenator still no start...
Need more info so we can look up wiring diagram? Dodge is the make, what is year and model? Sometimes when battery voltage is lost, it can cause problems?
If starter motor won't crank the engine, check starter motor wiring circuits. Any testing at starter motor make sure tranny is in park or neutral and parking brake is set. I haven't checked your security system info.
If you think the problem is the starter motor, usually you can take it off, lay it on the ground, hook up jumper cables properly from starter motor to good battery, at the least, it should kick out starter drive gear and spin.
My mitsubishi eclipse 95 gs wont start and theres no light on my dash bored it will cranck but wont start at all i need help asap
Since the engine cranks, the battery, starter motor/starter motor solenoid are most likely
good, so suspect everything else on the list. When you narrow it down, re-post with a
more specific question about that particular component, since 100s of components must operate
nearly perfectly for a vehicle to actually start.
Priority Action Part Type -- Cause
1 Inspect Battery -- Battery Discharged or Faulty.
2 Inspect Battery Cable -- Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Battery Cable Connector -- Broken/Corroded/Loose.
4 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
5 Inspect Ignition Coil -- Faulty Ignition Coil.
6 Inspect Wireset (aka Spark Plug Wires) -- Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug -- Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter -- Starter Motor Faulty.
9 Inspect Fuel Pump -- Low Fuel Pressure.
10 Inspect Solenoid Switch -- Faulty Starter Solenoid Switch.
11 Inspect Fuel Pump Relay -- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator -- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch -- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive -- Faulty Starter Drive.
15 Inspect Fuel Injectors -- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer (inside fuel tank) -- Clogged or Dirty Fuel Pump Strainer.
17 Inspect Engine Control Computer -- Incorrect Operating Information Being Delivered and Sent From The EEC (faulty computer)
18 Inspect Fuel Tank -- Fuel Tank Empty.
19 Inspect Carburetor -- Carburetor Flooded or Faulty Choke.
20 Inspect Distributor Cap -- Worn, Loose, Cracked, or Incorrectly Installed Distributor Cap.
21 Inspect Distributor Rotor -- Worn, Loose, Burnt contact surface
22 Test/Inspect Neutral Safety Switch -- Faulty Neutral Safety Switch
Got a mazda 626 2001 motor turns over bt dosnt start the coil is good and so r the plugs and wires motor wont turn over with key either have to acr the starter
Make sure you have a spark at the plugs. Also if you can , check fuel pressure and fuel out of injectors....a little more work.
Hope this helps
Good Luck
My car wont start
3 Inspect Distributor Cap -- Distributor Cap Cracked or Burned.
3 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
5 Inspect Coil - Ignition -- Faulty Ignition Coil.
6 Inspect Wireset -- Worn, Damaged or Faulty Spark Plug Wire(s).
11 Inspect Relay - Fuel Pump ----- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator --- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch --- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive --- Faulty Starter Drive.
15 Inspect Fuel Injector --- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer ---- Clogged or Dirty Fuel Pump Strainerat.
1helpful
2helpful
2answers
1995 volkswagen passat vr6 wont start the injectors are getting fuel but its not getting fuel to the engine. The injectors are getting spark and the fuel pressure is good.
if it fires then dies, you have to reset the alarm system with the key/remotes???otherwise you need to plug in the diagnostic computer(saves hours of "fun")
2answers
Wont start turns over but no start
1 Inspect Battery Battery Discharged or Faulty. 2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable. 3 Inspect Fuel Filter Clogged or Dirty Fuel Filter. 3 Inspect Distributor Cap Distributor Cap Cracked or Burned. 5 Inspect Coil - Ignition Faulty Ignition Coil. 6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 8 Inspect Starter Starter Motor Faulty. 9 Inspect Fuel Pump Low Fuel Pressure. 10 Inspect Solenoid Switch Faulty Starter Solenoid Switch. 11 Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay. 12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator. 13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 14 Inspect Starter Drive Faulty Starter Drive. 15 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat. 17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC. 18 Inspect Fuel Tank Fuel Tank Empty. 19 Inspect Carburetor Carburetor Flooded or Faulty Choke. 20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
1995 FORD EXPLORER 4X4 6 CYL 4 DOOR WONT START
Fords have inertia fuel cut off switch. You need to check that first. If you dont have fuel. If you have fuel and no spark you need to check for inj pulse to injector. Make sure no fuses are blown. If no spark and no injector pulse then replace cranksensor.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
