My razor phone will not charge after water damage. everything else works just wont charge battery. replaced battery and new one won't charge. got new phone and new battery and have same problem with them. being told by insurance company that i wrecked the chargers and new battery by using them in water damaged phone.cAN CHARGER USED ON OLD WATER DAMAGED PHONE DAMAGE NEW PHONE AND NEW BATTERY JUST BECAUSE IT WAS USED TO TRY TO CHARGE OLD WATER DAMAGED PHONE? My LGVX9400 got some water damage. And although the phone itself works fine (i can use it when it is plugged into the charger) the battery eventually died and now it wont charge it back up again. I ordered a new battery and i let the new one charge for over 24 hours thinking it was getting a full charge but then realized it hasnt charged at all and the phone wont even turn on with the new battery. BTW: that little white dot under the battery, it turned from whate to pink, does that have anything to do with it?
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
SORRY IGNORE THE FIRST PART... SOMEHOW THAT REVIEW GOT CARRIED OVER TO MINE
