I have a Maytag Bravos 300. I tried to remove the tub to clean the lint filter and the tub came up a little and then when we put it back, it seems to be locked in the down position. The tub won't lift out and it is as if it's locked down and will throw an overload code. We can't lift it back up.
SOURCE: Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
SOURCE: Maytag Performa PYG2300AWW Problem: How
Please CLICK HERE
You will get some idea from the manual..
Goodluck,
Please dont forget to rate the solution
SOURCE: How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
SOURCE: Bosch Axxis dryer - lint filter indicator lights up
Make sure the exhaust vent duct is clean all the way to the outlet.
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF
Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Testimonial: "Thanks so much!"
There is a special tool they sell, which I did not want to buy. There is a video on YouTube showing a guy using a jack and 2x4s and that is what I did. A bottle jack is $25 at auto zone and always good to have an extra for the vechicles. It took a few pumps and they came apart. You might notice that the shaft is rusted and if that is the case might has replace the bearings and shaft.
