Akai PT46DL10 46" HDTV-Ready Television Logo
A
Anonymous Posted on Jan 12, 2014
No red power light on - Akai PT46DL10 46" HDTV-Ready Television
2helpful
Power light red ,internet light red no other
Most of the time a red internet light means that the box can't find the internet / can't find it ISP / can't get on the DSL what ever.
Might be the modem, might be the power adapter.
5helpful
2answers
Epson r290 no power after i turn off because 2 red light appears
while printing the two red lights turn on and stop printing,i press the power to off.. i turn it on so many times but still no power.. in the morning, i press the power to on and the 2 red lights appears again, then i turn it off, ..i try to turn it on many times but still no power. help me pls...
Power light on& status light on
The power red led indicates that your device is "power on" , but the status led still red and turn to green if the device ( video input )received video signal ( from DVD player, Laptop etc. ) .
2answers
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
3answers
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
2helpful
Help fix screen t.v.
What red light are you referring to? If you are talking about the red l-e-d power light beneath the screen, that is the power off light. If that red light light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply.
Three red lights
three red lights (no error message) - two reasons for the red lights: hardware failure or power supply unit failure.
when the three red lights is showing check the light on the power supply unit. if the light is green you console is experiencing a hardware failure. you need to send the console to MS service center or if you have no MS support in your country look for someone who knows how to repair the console or go to xbox-scene.com and look for information on how to repair the console yourself.
if the light is orange, red or no light at all, there might be a problem with the power supply unit. disconnect and reconnect the power cables from the 360 and reconnect them again. if there is an inter-cooler connected at the back of the console, remove the inter-cooler and turn on the console without the inter-cooler. try also a different wall socket and if the light on the power supply is still orange, red, or no light when you turn on the console you need to replace the power supply unit.
1helpful
3answers
Xbox360
Is the it the power supply red light?
The red light may indicate that the power supply is too hot or is overheated. Therefore, you should let the power supply cool for several hours in a well-ventilated space. During this time, you should not try to turn the console back on to allow the power supply sufficient time to cool. As soon as the power supply has cooled off, the power supply light will change from red to orange, and you can turn the console back on.
If the power supply light is still red after you have let the power supply unit cool in a well-ventilated space, the power supply unit may require replacement.
Also make sure the power msupply is plugged in correctly.
You could also purchase a new power cord.
Good luck
Mick
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
