Can not see screen unless a light shines through lcd with back off of screen
Your backlight lamp, (Bulb), or the Inverter is bad.
1.General instructions, and photos, for replacement of a typical laptop backlight,
http://www.ccfldirect.com/lcdtutorial.html
2.Instructions for completely disassembling a Toshiba Satellite A135 laptop. The reason I included this is twofold.
A.It shows, and tells exactly, how to remove the LCD screen from your laptop.
B.It shows you that the following information in link 3, on how to replace an Inverter in a Satellite A105, will work for your Satellite A135.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
(At the bottom of this page you will see Page1:: Page2:: Page 3:: Page 4
You are on Page 1. Just click on the white Page2, and so on, to continue)
3.How to replace an Inverter in a Satellite A105,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
FIRST! Always remove all power! AC adapter, (Charger), and battery.
Second! Observe anti-static guidelines!
Third! This ain't tough! It just looks hard. Once you see how simple this is, I'm sure you'll agree with me.
Yes i do have very dim light but can see if I get close but barely.
i do think it is the inverter or blacklight bulbs thanks for them help I have a inverter on it's way hopefully that will do it if not i will change the screen
Do you have a dim screen where you can barely see the screen unless you look at it real close?
