Top fridge not working bottom freezer seems cold
SOURCE: Frigidaire Side-By-Side Top Not Cooling
sounds like its froze up. the coil is in the back of the freezer and blows into the freezer via a fan then cold air is carried to the fridge via another fan. more than likely condensation due to weather conditions has built up on your coil and has froze up or your fridge fan has stopped working. unplug fridge for a day to let thaw, if this doesnt work check you air distribution fan in top.
as for the lights not working in the freezer the switch is on the left hand side of freezer wall under ice holding tank sometimes water from thawing ice get on it and it wont come out all the way, take a blow dryer to it to thaw and dry it out.
SOURCE: Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
SOURCE: losing coldness in freezer and
Condenser is in need of being cleaned badly or your fan motor to cool the condenser is not operating. Compressor is overheating. Removed the panel in back of the refrigerator and clean the condenser so air can freely pass over it for heat removal. Allow compressor to cool off before restarting it.
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
