Alcatel One Touch FIRST 20 Cordless Phone Logo
A
Anonymous Posted on Jan 13, 2014
How to set caller id in Alcatel Versitis C650 cordless phone
1 Related Answer
Anonymous
  • 122 Answers
  • Posted on Apr 05, 2012
SOURCE: Alcatel audience 42 landphone, how
Alcatel Audience 42 cant support ID callers.
How to get a caller display service on the cordless phone
Buy a cordless phone that has caller ID and if you don't already have caller ID service you need to order it from your phone company.Most every new cordless phone has caller ID
Caller Id not showing up
go on settings and on call settings and caller id
Uniden Cordless Telephone with Dual Handsets and Caller ID DXI-55
check if you have a manual. from there search up in the manual caller id settings. you have turned off the caller id option.
2answers
How to activate caller ID after moving the phone
I know it seems like an obvious thing but did you make sure that you have caller ID on the line from your telco provider?
CALLER ID-CANNOT SET IT
there really shouldn't be anything to set up. if you have another caller id box or phone, try plugging that in to the phone jack first checking for dial tone, then the caller id. if neither are working, call your phone company. if only the caller id is still not working, ask your phone company if it is activated.
hope this helps.
wg
1helpful
2answers
Caller id not working
US phones use Bellcore FSK caller id. India uses DTMF caller id. Buy a DTMF- FSK converter at a telecom shop.
Caller Id
Are both cordless handsets used with the same main line ?
19helpful
7answers
Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
1helpful
2answers
Caller ID Problem on the GE2811 Twin cordless phone system
How to get the caller ID to work on the additional GE DECT phone handsets. You must follow these steps in the exact order :
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes. reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in.
It takes about another 10 minutes after that before all phone handsets start recognizing caller ID.
Top Alcatel Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Paul Katynski
Paul Katynski
Are you an Alcatel Lands Phone Expert? Answer questions, earn points and help others
