Door is lock when off when I hit start it opens. Also the drum only turns one direction.
SOURCE: "Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
SOURCE: LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
SOURCE: LG INTELLOWASHER DD 7KG DOOR LOCK STAYS ON WAY TO LONG
Never heard of that; I would try a new door latch as I have never had a bad control issue with the operation of the door latch. There is no real way to test it. I can getb you the latch if interested. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
SOURCE: lg washing machine wm-1460fhd door locked wont
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
SOURCE: door wont open on LG WD-8016C
mine either. The handle seems to break easily. Try getting a butter knife and pushing in from the left hand side, this will undo the latch.
