On both -r and +r dvds
SOURCE: I need to unlock my memorex mvd2016 dvd player so
Sorry this specific model of DVD player cannot be unlocked with your standard remote - no hacks available for this player, sorry.
SOURCE: "Wrong disc" memorex dvd player error
Sounds like a build up of dust on the lens.
2 options -
Either buy a DVD lens cleaner
Note DVD LENS cleaner, NOT DVD Cleaner the latter is for the discs, not the player
or second option is to remove lid from your player (usually 5 or 6 screws) and gently swab the lens with a cotton bud or similar soft lint free product. Try not to push too hard on the lens or you may damage the mechanism.
The lens is really obvious as it faces upwards and looks like a small round clear glass bead.
Make sure its unplugged too!
SOURCE: My new memorex dvd player mvd2016 is stuck in
Please check your connections and placement of cables. The green colored cable must be in the green hole on the dvd player as well as the television. Likewise the blue cable must be in the blue hole on the dvd player and the television. Same thing with the red cable. If you are connecting a yellow cable to a green hole you are going to get a black and white picture every time. If this is not the problem sometimes there is a monochrome choice in either the dvd player menu or television menu but this is highly unlikely. This is normally due to connecting the dvd player incorrectly to the television.
SOURCE: why is picture scrambled on
The MVD is a progressive scan DVD player if your TV is 1080i or shows interlaced images only and doesnt have the option for progressive scan this would be an issue. I would suggest trying this DVD player on another television first. Also what is the model of your television?
Another issue is if you have and HD TV and are hooking up the A/V jacks to the HD component inputs this would also provide a jumbled picture. It would be a good idea to check and make sure that the A/V cabled are inserted into the correct input.
