Fisher and Paykel WL26CW2 Top Load Washer Logo
A
Anonymous Posted on Jan 13, 2014
Fisher paykel drain pump repair - Fisher and Paykel WL26CW2 Top Load Washer
keith jones
Level 3:
Master:
  • Fisher and P... Master 747 Answers
  • Posted on Apr 21, 2018
keith jones
Level 3:
Master:
Answers
747
Questions
Helped
314799
Points
1478
Cannot repair replace only
5 Related Answers
Anonymous
  • 183 Answers
  • Posted on Aug 22, 2007
SOURCE: fisher & paykel GWL08 washer
faulty pcb Regards Advisor
Anonymous
  • Posted on Jan 22, 2008
SOURCE: RE: won't drain
I had the same symptoms (washes normally, but won't drain/spin) It would only make a faint hum. I found it fairly easy to lift and tilt back the upper section id by removing the front two screws under the lid. The aggitator came out easily by removing the softener cup and unscrewing the large plastic wingnut inside. The upper plastic shroud came off by carefully removing the eight or so plastic tabs. Once the shroud was off, I could lift out the main wash tub. With the wash tub out, I was able to remove all remaining water from the holding tub with a cup and sponge out all water down into the depression where the pump assembly is located. One screw removed the cover to the pump assembly. Once apart, I found a thin piece of plastic was jamming the pump impeller from spinning. I blew through the drain hose from the back to ensure the drain system was clean. Reassembled in reverse in less than 10 minutes. It worked. Thanks Fixya!!!
JULIANFIX
ALBERT GARCIA
  • 975 Answers
  • Posted on May 20, 2008
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Anonymous
  • 12 Answers
  • Posted on May 14, 2009
SOURCE: washer will not drain
90% chance that is the pump is pumping water at all, there is blockage between the tub and the drain pump. If there is no water coming out of the drain line. either extremely clogged(odd) or pump motor is bad, and windings are not allowing rotation.
luisa_sgro
  • 713 Answers
  • Posted on Sep 21, 2010
SOURCE: water will not drain out
Hi just read your posting.1st you need to drain some of the water by hand using a small bucket or pot ,enough so you can lean the machine back to look under the machine.If you have the old style of pump you will see a red or black fan under the machine front right.If you have this pump turn the fan a few times to loosen it.The fan should turn freely.Then put it back on its feet and select a spin cycle and push start.It should start to drain and then spin.Please reply on how you got on or if you have the new type of pump which has no fan.Looking forward to your reply.
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
2answers
Fisher paykel error code 37
check drain pump is not blocked or faulty
Fisher & Paykel GW612 won't spin
you want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
1helpful
My washing machine will not light up
Generally this problem happens when the drain pump starts to leak under the washing maching. A Fisher Paykel has a main control board under the touch panel that has direct wires running from it to the drain pump. When the drain pump leaks it shorts out the wire connecting it to the control board and blow out the main control. Look under washer and look for the drain pump (Drain pump looks like a fan from the underside.) You will most likely see residue from where the water has been leaking, built up on the pump. If all of the above is true on your machine, replace the pump and control board. Fisher Paykel includes an inline fuse to keep this from happening again.
1helpful
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
I've got Fisher and Paykel Excellence Top loader 7.5 My problem is, it won't unload or drain water. What do i have to do?
Hi, The washer wont unload or drain water until the drain pump is working. Get the pump off and look for debris. To remove the pump you unlock the tab and twist the pump a hair. The pump is on the bottom of tub.
1helpful
2answers
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
My fisher and paykel ecosmart glw 15 fills wash but do not drain. Can it be the water pump?
yes likely to be drain pump ...more than likley obstruction ( foreign debris in pump chamber)
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
