Select programme starts water fill then after 30 seconds defaults back to "select programme",tried all cyles,replaced ASKO new parts main control board and display board still problem, any help apprecaite please
SOURCE: Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
SOURCE: Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
SOURCE: asko w6021 still not working
check that all the plugs are in the correct position on the board,you may have introduced the fault,because the only fault you had to start with was worn carbons.did you break off any links maybe J4 etc if the original board had the link taken off and you dont do it on the new board you will hard program the new board and will have to order another board. is the machine heating.put on wool wash and select heating you should hear it start to heat.let me know.thanks Ian
SOURCE: asko 10505 runs through was
hi sir'
start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
SOURCE: Hello, I have the Asko W6761
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Toggle the power switch
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
W6761 seems to be weak at high ambient temperature.
Tsunett
Testimonial: "this is great, it worked! thanks so much"
not W6021, its a W6551
