What driver do you want to install?
I'got a Yamaha psr-E413 keyboard. Some of the notes dead. I screw off the keys and wash the rubber pads with water and clean the contacts on the PCboard,i put back the rubber pads,and i push the pads with my finger,all the notes are playing one by one. But when I put back the black and white keys some of the notes are dead. I think the rubber pads are worn out. Please how can I fix the rubber pads. It's not broken.
Hi
First things first. Ensure everything is totally dry, water can be left inside the domes of the rubber contacts. If one area (rubber contact ) is working correctly try moving this to the area which is not working. If the keys then work the problem is with the rubber contact - simply replace. If the fault is still there it could be that the contacts on the circuit board have worn out - you will be surprised how often this happens.
Either way :
Contacts are part : V3413601 or V747740R for the highest notes.
Boards if required are part : V869530R or V869550R
See attached.
Simply Google the part numbers if you require them or visit our store beckettsmusic.co.uk
