Question about Sennheiser HDR-45 Consumer Headphones
Problem with volume and on/off switches intermittent loss of sound
My harmon kardon av amp keeps losing its memory/settings when its switched off, it also loses audio on the 3/2/1 on the aux, dvd channel, intermittent loss of volume help, too good a system to bin thanks
could be the memory chip, I used to see this a lot with Panasonic tv's that would lose all memory settings ie channel and tuning memory, with the intermittent vol problem it sounds like dry joints in the amp section, always check the components around the heatsinks for dry joints, especially capacitors and transisters, pay to get your hands on a service manual showing all the layout and different componets.
May 30, 2010 | Audio Players & Recorders
2004 RX 330: intermittent power steering loss, hard to turn, so...
I think you may have a problem with your electric assisted power steering motor. Is the loss in power only when your are making sharp turns to the right or left?
Do you hear any load noises or squeling sounds?
You should have it inspected, Don't want you to lose control while driving.
May 16, 2010 | 2004 Lexus RX 330
Sugden a21a - intermittent loss of channel - fading in and out sometimes left, sometimes right. Always corrects temporarily when fiddle with function knob or quickly turn up volume when it bursts forth....
had exactly the same problem myself, changed the balance, and the selector until Sugden suggested the relay. this did the job, and my amp is sorted. Shouldv'e changed this in the first place. Good as new. Shaun
Mar 14, 2010 | Audio Players & Recorders
The left side sound is intermittent
Sounds like dirt in the volume control or a high resistance speaker wire.
Try switching the right and left speaker wires and see if the problem changes.
Aug 03, 2009 | Audio Players & Recorders
Loss of speedometer and lights intermittently
What bike are you riding? The Road Kings and Fat Boys, ect, with dash mounted ignition switches will ( from washing , rain, so on ) corrode internally and cause the symptoms you describe.
Jul 13, 2009 | 2003 Harley Davidson FLSTFI Fat Boy
Intermittent audio...picture fine
Does this model have a headphone jack? If so, plug a pair of headphones or external speaker into the jack, turn the volume to an acceptable listening level and see if the problem goes away. If so, the headphone jack may be bad.
Mar 02, 2009 | RCA E09344 Under Counter Kitchen TV 9"...
Intermittent loss of mobility, get beep beep sound
I sounds like the switch is not making contact relieably. Make sure your key is clean and if that does not work, than the switch inside the console will need to be replaced. Contact Pride Mobility for a technician local to you.
Nov 12, 2008 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Loss of sound
Try the following:
1) Check your headsets. Use another player to test it. If it works then the problem is within your MP3 Player.
2) Adjust the volume. If it does not work...
3) Reset your MP3 player by pressing the reset button found below the volume buttons.
4) Unlock the hold switch.
Jun 14, 2008 | Sony NW-E002 MP3 Player
Sennheiser HDR-45 Consumer Headphones Logo
51 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
