Question about Neff 23 in. T4343 Electric Cooktop
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob. I also have the red key about the on switch and cannot swithc it on!
    Novelist:
  • 222 Answers
Hi gud day, more of ceramic hob is touch control,try to stay ur thumbmark wen the unlock circle to unlock if u hear the sound it means is unlock also in the other wat u want to operate,or clean the surface coz some oil is coz of not operate properly. tnx gerbee
Posted on May 29, 2009
    New Friend:
Just give a long press on the symbol " a circle inside a circle attach to half oval shape " in otherway which indicates to the left top heater.
This has worked for me :-)
Posted on Feb 19, 2014
    New Friend:
Make sure you have proper induction pans
Posted on Nov 20, 2011
2 Suggested Answers
6ya staff
SOURCE:
john_youn506
SOURCE: How do i unlock my neff hob? Red key above on/off
Hi I have just had the problem of accidently locking my Neff Hob.
If you hold down the L Lock button for about a minute it unlocks.
Posted on Jan 05, 2011
My Neff induction hob has prgressiely getting worse. All the lights start flashing and only hob will work. But after 10 mins the other hobs start working. The flasing gets worse if you try to start with...
Hi, if you take off the magnetic knob & let it flash a little longer, then switch off & on again it will work. Ours is doing the same. The book says it needs cleaning, as do the customer services people but I've cleaned & cleaned it & I assure you it's spotless. You don't have to wait 10 minutes though to start cooking, just 1 after switching off. It is very annoying though & I think we will be getting an engineer out to look at it.
Nov 29, 2009 | Neff 23 in. T1443 Electric Cooktop
We have a neff induction hob which for some reason has no instructions and my little brother managed to lock it (so that a key symbol lights up above the on switch and all functions are disabled, i need to...
Try - set all hotplates to setting 2. Switch off jot plates one after another starting with front right in clockwise direction, touch main switch for at least 5 seconds & a signal will sound - this activates & de-activates the child lock - or so the instructions say...
To use the hob with the child lock on - it says to press the main switch for more than 4 seconds & that lets you use it.
Jun 15, 2009 | Cooktops
Mar 18, 2009 | Neff 23 in. T4343 Electric Cooktop
Hob lock
gud day,the key symbol is the lock try to unlock the unit by touching the sensor,or check the manual how to unlock.
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Child lock on for neff t1443
gud day,not all models of ceramic hob have a child lock,check it 1st ur unit if have it,if we have,touch the circle w/sign of key to lock the ceramic for ur child,to unlock touch again.u see the ligth red is on it means the lock is in ON.easy to unlock even ur child by touching the key sign,for ur safety to not use ur unit,unplug the unit if it not use.
Aug 21, 2008 | Neff 23 in. T1443 Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
May 30, 2008 | Bosch 24 in. PIE675T01E Electric Cooktop
Neff 23 in. T4343 Electric Cooktop Logo
15,131 people viewed this question
Top Neff Cooktops Experts
Paul Carew
Clive
Clive
ray gallant
ray gallant
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
