Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
A
Anonymous Posted on Jan 14, 2014
I need a handle forFrigidaire Elite Model No RE 806 EW-1 Serial No NF 22802709 - Frigidaire 30" Self-Cleaning Freestanding ...
I am having trouble finding a handle parts number
5 Related Answers
Anonymous
  • Posted on Jan 04, 2009
SOURCE: I don't know where to look for a Glass Cooktop Replacement
What is your model number and I can look up the part and tell you what they cost so you can call some appliance stores for comparison
Anonymous
  • 6784 Answers
  • Posted on Mar 25, 2009
SOURCE: self cleaning instructions
Hi. i have created a link for you to access the actual manual you are needing. please feel free to print it out or, save it to your CPU for safe keeping.
Click here for your Frigidaire manual.
please rate and god bless.
Anonymous
  • 189 Answers
  • Posted on Mar 19, 2010
SOURCE: The self cleaning instructions for my Frigidaire
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
SOURCE: Range Cleaning Cycle not Working
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Anonymous
  • 43501 Answers
  • Posted on Nov 24, 2010
SOURCE: 30 " self cleaning oven,
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
1helpful
How to use Frigidaire self cleaning instructions lost manual
Good Afternoon friend, thanks for your inquiry!
To locate instructions regarding self-clean on your Frigidaire range I would need to have your model number. I have provided a link for you to use once you have your model number to locate any Use and Care Guides available on your current appliance. I hope this helps to some degree and if you need assistance please reach back out. -Matt
Owners manual for model FWS558W-3
Hi friend, thank you for your post!
I see you would like to set your Frigidaire range to self-clean but I did research that model number and could not locate any information on it. Can you please verify the model number? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
What does pyr mean?
Good afternoon friend, I appreciate your post!
I see you are having trouble with the self-cleaning feature on your Frigidaire range and you are receiving error code "PYR". However, it appears "PYR" is an invalid error code. May I have you model number please? Typically you can locate your serial tag on the storage drawer on the right hand side. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.If resetting the power does not correct the issue, could you please inform me of the new error code or if your rangecontinues to display "PYR"? I look forward to your reply. -Matt
Oven elements not working
Good Afternoon Friend, thank you for your inquiry!
I see that you are having trouble with both your bake and broil element on your Frigidaire range. Can you think about what may have happened prior to this occurrence? For instance, did you notice any error codes or strange noises? Also, do you have an electric or gas range? May I please have your model number? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can assist you better in pinpointing the problem. Thank you! -Z
Replace oven door handle
Hi blah_blah894 - Are you trying to replace the oven door handle or need part number? If so, I would like to further assist you but in order to do so; do you happen to have the exact model number?
1helpful
I have a frigidaire Model FED387CHSC Serial # NF01112534. I cannot find the manual. I need instructions for cleaning the oven.
http://www.retrevo.com/support/Frigidaire-FED387CHSC-Ranges-manual/id/2364ci257/t/2/
click on the above link it will take you to a site were you can download the manual for free
Oven door is locked shut. How do we get it to
Try cutting the power to it. ALSO push in to relieve the tension on the latch while attempting to open it.
Manual for model re806w-2 serial nf12800097
I have model # RE806W-1 Serial # HF11801071. Need Manual
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
