If they are both the same model, make sure both the channel and ctcss codes match, as there can be 38 codes per channel, if they dont match u will not be able to communicate between them
http://www.motorola.com/mdirect/manuals/T58xx_User_Manual.E.pdf
that will show you how
hope this helps
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either + or – to turn On or Off.
3. Press the PTT to confirm or MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
SOURCE: I'm searching for a User Manual Walkie Talkie T8550R Camo
I think you'll think this is fantastic: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
SOURCE: i would like a manual for a technika TA-716walkie talkie
Tesco does not list operating manuals on their web site, so I suggest that you contact them directly by following this link:
http://direct.tesco.com/help/contactus.aspx
They should be able to provide you with the needed manual.
Bill B
Testimonial: "Thanks Bill. Much appreciated"
