I am using my sansui SW-100 as a sub only, with a single input wire from my 5.1 amp. On the back of the sw-100 is a Hi level input & output. I have 2 spare speakers how can I get them to work? Does it require something on the input side, to have the speakers operate on the output side at the moment they dont.
Looking for a schematic diagram service manual for sansui SW-X2 powered subwoofer
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
SOURCE: dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Enjy!
SOURCE: I have a pair of peavey messenger pro 12
they should work and sound awesome as well. your amp should handle the set-up with no problem.
SOURCE: How do i use the high level speaker inputs on this snell QBx sub.
Most likely, you simply connect the speaker wires to the high level inputs, along with the cable from your amp.
Given that Snell's are high-end speakers, I would recommend that you contact their tech support for your question. They have a specific email address for technical questions on their Support Page.
SOURCE: When I Connect the LFE Output of the Amp to the
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Infinity-PS-12-Subwoofers-manual/id/21470dj882/t/2/
I'm assuming your amp for testing was NOT a subwoofer output. I could be wrong.
Your source is responsible for creating LFE output. Are you sure it's doing that?
Tune an FM station and connect any other active RCA output from the source (like a Tape Out) to the sub
Making Cash more than $15k to $18k consistently just by doing basic online work. I have gotten $18376 a month ago just by working on the web. Its a simple and basic occupation to do from home and its profit are greatly improved than customary office work. Each individual can join this activity now just by pursue this link……..go to this site home media tech tab for more detail support your heart :*here…………………..===>>> www.gocash7.com++
Don’t copy "++" with web address
