Some of the reasons sim card not working in your mobile
1.Bad SIM -if it wasn't unlocked you'd get a message asking you to enter a PIN.Get the pin from an online vendor like Unlock Zone Unlocking the LG CU500 mobile phone .
2.With a warning that you have 10 attempts to enter the correct PIN code or it could be locked forever ,if you don't get that message it's "mostly likely" unlocked.BUT find a phone with a known working SIM and see if it will work and connect to the network.
3.May be a hardware problem try flashing with a custom rom.
4..This has to be a problem with the SIM card slot, which is soldered down to the logic board. It's possible that it's a mechanical problem , you might be able to open it up and discover
that the card-detect switch is failing to detect SIM card insertion.
5.The os system has been updated and your phone is not being recognized with the right settings , this happened after a update a year or two ago.
Hi, maybe there's a problem with the SIM card or the SIM card is not compatible. Also, your phone might be network locked. You may check that in the following guide for LG phones: http://www.fastgsm.com/en/page/how-to-unlock-lg-gt540-optimus-gs290-kp500-cookie-gd510-pop-ks360
SOURCE: need unlock code for lg ks360 mobile phone
Hi Friend,
Kindly follow the instructions in the below mentioned link and you can find by your own the unlock code
http://www.pb4kn.co.uk/ks360_unlocking.htm
If this is helpful and solved your problem kindly rate this
Thanks for using Fixya
Regards,
Ayyasam
SOURCE: Sim Card Problem In LG Vu
This happened to me too. A temporary fix is turn off your phone and put it in front of a really cold air conditioner for about ten minutes. Then turn it on but make sure you keep it in front of the ac to keep it working. What happened is your sim card reader has a thermal problem so you will need to take it in unless you want to spend all your time in front of the ac (which will get expensive...)
Warning : Do not enter
any wrong unlock codes on your LG GR500 Xenon mobile phones. If you
enter over a certain amount of wrong unlock codes on your LG GR500 Xenon
mobile phone, your phone may get hard locked and sometimes become
unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
