SOURCE: Unit not freezing , evaporator fan wont run
If this is a Bev-Air, don't think the door switch will control the fan. At the evap, there is a temp sensor called a fan delay. When unit goes into defrost mode, this warms up. Some also serve a dual purpose. It will terminate the defrost cycle at a certain temp., say 51 degrees or so, at the evap. Anyway, when unit comes out of defrost, it keeps the fan off so it allows the evap to cool quicker and to prevent circulating warm air. This could be your problem. Not a hard fix but they can be a pain sometimes. Outside chance that the unit is low on refrigerant (freon). This will not let the evap get cold enough to trip the sensor back into position to turn the fan on. Good Luck. Restaurant Parts and More carry alot of Bev-Air stuff. 1-888-814-1110. Ask for Rick
SOURCE: evap fans not turning on
If this is a commercial unit, you're too low on refrigerant (freon). Freezer should be about a minus 10 degrees for the evap and high side is ambient converted to a psi for the type of refrigerant that is in the system plus 25-30 psi.
The evap fans will not come on because the evap is not cold enough.
Hope this helps and good luck.
SOURCE: I have an Amana TR21S4W refrigerator/top freezer.
I replaced the condenser fan and everything is working again.
Testimonial: "i solved this problem myself... hopefully someone else can learn from this?"
SOURCE: pulled out wires from compressor on a servis
Most of the time the compressor reads left to right Start common run. Black is common red is run the other one may vary in color. Rus
SOURCE: Looking for a wiring diagram for a GLT-2-32
1. Freezer coil must be cold enough to deactivate fan delay control.
PS it is a RLT232NUT 4 DR FREEZER SEMI HERM.
