Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's GuideGood luck from
Headsets Direct!
