Do not have the code list associated with the RCA RCRPS02GR
1980,1985,1983,1987 are the codes to check. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Electrohelponline
SOURCE: "Code List" for RCR311B
Find codes for RCA remotes here:
http://remotefinder.rca.com/default.aspx?site=rca
SOURCE: please provide me a site which I can access the 4
http://www.thompsontv.com/rcarc.html
Please rate and reply.
SOURCE: i tried all the listed 3 digit codes for my tv and
Hello wvl33:
Hopefully this page may help:
CLICK HERE:
It also might help if you put your TV brand and model number up so we can do a more thorough search for you.
Direct Code Entry
Direct Code Entry lets you enter a code from the accompanying
code list for your brand of device. It's not as easy as the other
methods, but it's potentially the fastest method.
TIP: Each device key is associated with a type of device-
the TV is preset to search for TVs, SAT•CBL•DTC for satellite
receivers, cable boxes or digital TV converters, DVD•VCR
for DVD players, and DVR•AUX for DVRs. To program a
device key for a different type of device, see the Changing a
Key's Device Type section.
[1] Manually turn on the device you
want to control
[2] Press and hold the device key you want to program (the
POWER key illuminates).
While you're holding down the device key, use your other
hand enter the first five-digit code for your brand in the
code list (the POWER key turns off after the first digit).
[3] When you've finished entering
the five-digit code, keep holding
down the device key and look at
the POWER key.
Is the POWER key
illuminated?
YES: You're done! You've programmed this device key
NO, it blinked four times and turned off: You have
either entered a code number that is not in the code lists
or missed a step in the code entry procedure. Try step 3
again
