Question about Sony BRAVIA KDL-40V3000 Television
Error code cc00
I have a "SCIENTIFIC ATLANTA EXPLORER" 8300HDC HD DVR Time Warner Cable box that is stuck on "cc00." The unit will not reboot and freezes with cc00 on the display.
5 Suggested Answers
6ya staff
SOURCE:
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Posted on Feb 18, 2008
Anonymous
SOURCE: TV not finding Digital Channels from Cable Box
We have Comcast and we plugged the cable straight into our Bravia, searched for Digital Channels and it found 131. We actually get all the HD channels that we had using the box, plus a few more. It's worth a try.
Posted on Aug 24, 2008
Anonymous
  • 5 Answers
SOURCE: Sony 52" Bravia LCD will drop picture and sound for 1-2 seconds
the only thing that i can think of is that the cables and connections are bad but if that is not the case it may be the internal components of the tv. my guess is that the tv was dropped or jumbled around while transported and what happened was internal components were broken or just mixed up so go to the retailer and get a refund or a new tv. hope this helps
Posted on May 22, 2009
Anonymous
  • 117 Answers
SOURCE: connecting a standard cable box to an HDTV and
are you connecting by scart ? if so some hdtvs send signal backfeed/try aerial tv out to tv/also try basic scart lead as scarts can be faulty dont fit a pound shop one get a top one from maplins etc
Posted on Nov 10, 2009
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
May 01, 2016 | Magnavox Televison & Video
Front power indicator blinks, clicking/high pitch sound
  1. This how to is to repair hard drive, software and some firmware issues that can arise on specific cable DVR and DAC and DCT boxes, First instructions are for Scientific Atlanta hardware. Firstly, one should be certain that the cable box has the coax (cable antenna wire) hooked up to the CABLE IN or RF IN on the box itself and be connected to a "hot" outlet - one that you KNOW works. Test it by connecting a TV directly to outlet. If you get a weak signal, the box will too. Digital boxes require a clean SNR. Remove in-line "surge protectors" on the coax. These prevent the signal from being sent by your cable provider to your box.
  2. Scientific Atlanta DVR or High Def boxes:These need to be "booted" or reset when certain errors occur. No audio on certain channels when SAP is NOT set to ON and confounding error codes that one can't seem to get out of. Common yet confounding errors are : No Audio on DVR Playback. No Audio on Certain Various Channels (ruling out SAP which can be enabled through the box, OR the television set itself) there are easy ways to test. If some channels audio is in Spanish when they are normally in English...the obviously you will check SAP first.
  3. Disc errors. On screen error on your TV that says something like..."there are problems with your storage disc.." or upon DVR playback instead of playing your program it loops upon itself and plays nothing.
  4. two different steps to reboot box: Simultaneously press VOL+ VOL- and "INFO" buttons on box itself, not from remote. Box will then display "bOOt" and shut down totally. Do not press ANY buttons or try to power on said box. Wait for the correct time to display on the box. This process can take anytime from 40 seconds to hours, depending on how fast the cable company's servers are responding at that moment and whether or not you have enough of a cable signal to fire up the download process. If you call customer service for your provider if this does not work, most likely a truck roll will be run for a tech to come out to your residence to fix the signal issue.
  5. When the correct time display is on the Scientific Atlanta box, THEN power on box and problems should be solved. An alternate way to reboot box is to simply unplug unit from power supply and replugging it in. Simply powering it on and off with the POWER ON button will not solve anything.
  6. On a Motorola box and/or DVR, the easy VOL+ VOL- and INFO will not work to reboot. Remove AC power plug from wall socket and wait 30 seconds to a minute while box is powered ON. Plug back in to wall socket.Box will "do it's own thing" and power itself on on it's own after the cycle has been successful (30 - 60 seconds) and the box should power itself back to the ON without you doing anything. Time will not display on Motorola"General Instrument boxes unless you set it up to do so in the settings mode.
  7. Common IControl/On Demand errors:
  8. MOTOROLA BOX Error 225 : A billing lock to prevent you from ordering pay per views. If your account is past due, or if you have an order to move to a new address in the service provider's "system", this is a preventive measure to keep customers from loading up tons of expensive pay per views and skipping out. Your cable company cannot over-ride this error. If you are not in above situations, your provider can "up" the limit on the box and clear it so you can order PPV through your remote control.
  9. SCIENTIFIC ATLANTA: for above mentioned error code, your SA box will display not a code but a prompt to contact your provider by telephone. Same issue.
  10. MOTOROLA BOX ERRORS 204...203.. 207..these may be easily solved by simply reseating the coax and then rebooting box.
  11. SCIENTIFIC ATLANTA ERRORS 2207: reboot box. This is a general code meaning the box has lost contact with the server. All of your iControl /On Demand orders come through your local cable head-end's servers. If and when it gets overloaded and times out, error 2207/207 will happen. Most of the time this is temporary. Reboot box, try again in 15-20 minutes.
  12. DVR BOX not displaying/recording/playing items:
  13. Reboot. Good chance of fixing.
  14. If your TV displays "One Moment, Please. Your Channel Should Be Available Shortly..." this is a SIGNAL issue. Reseat the line running from wall to the CABLE/RF IN on the box and at the outlet at wall. If no joy, call cable operator.
Nov 18, 2007 | Hitachi 53UDX10B 53" Rear Projection...
HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
Oct 30, 2009 | Toshiba 32AV502R LCD TV
Download movies from explorer 8300 hdc dvr to computer to burn
Not gonna happen. SA uses a proprietary file system. The USB is only designed for a keyboard or mouse when in a special diagnostics mode. The best you can do is use an eSata drive to the port on the back. IF you have the Mystro software on the box (most do) it won't even allow you to move programs to the storage drive until the box's drive is mostly full. Even then, I'm not sure that it gives you the option to choose what you want to offload.
You are best off buying a DVD burner (stand alone unit) or output the video to your PC. and re-encoding it to the file you want. Alternately, wait for the Series 4 TiVo with tru2way.
Sorry to be the bearer of bad news.
Mar 11, 2009 | Pioneer DVR-107D DVD±RW Burner
I just bought a Samsung 40" LCD 550 series and hooked it up to a Scientific Atlanta 8300HDC DVR. When watching an HD channel, it seems to "skip" or almost "drag" continuously. Any...
The first step you sohuld take, in my opinion, is to have the cable company come out and test your line levels to make sure there isn't a lossy connection somewhere.
You might also try rebooting your cable box by turning it off, unplugging it for a minute, then plugging it back in.  I have this issue with the same box and I believe the problem may be that the live recording for pausing and rewinding gets bogged down after a certain period of time.  I've had four of these boxes and had this issue with every one of them.  They seem to have a problem when the cable company pushes an update sometimes that corrupts the firmware and causes problems (my fourth box just failed tonight, that makes four failures in about eight months).
Dec 06, 2008 | Televison & Video
Help!
Unplug the unit> Remove> Take out to back yard> Smash repeatedly with a sledge hammer of at least 2Lbs> Mail the resulting material to cable company preferably next-day.
Apr 24, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Set top box and remote control
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Feb 03, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound time warner cable
Time Warner Cable just sucks!!!
Feb 02, 2008 | Computers & Internet
Sony BRAVIA KDL-40V3000 Television Logo
653 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
