SOURCE: GE Side-By-Side Refrigerator Model GSS 23QSTA SS
I have a GE refrigerator and just had a technichian repair it. My problem was with the condesor relay and also the ice dispensor controls would not work. The tecnician replaced the main electical board on back of fridge and said that GE extended the factory waranty on this part. He was surprised that I wasn't having any cooling issues. He said that when most boards go bad there is a cooling problem.
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
SOURCE: coils freezing up!
Outdoor coils dirty creats high head pressure which in turn destroys a hermetic compressor for the fact that a hermetic compressor uses Superheated vapor to cool windings..Your post is so vague but for the fact you advise a service tech...
SOURCE: KELVINATOR KSR20C
One might think so, YES! look on one of the door panels that you can remove! Thank-you-very-much!
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
