Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Warm cold pack delay without battery
Quick charger Dewalt 18V
6ya staff
SOURCE:
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: 18v. charger (dewalt)
I did a little hunting and it seems you really want to use your 110v charger on a 230v supply.....
So you could use a transformer (LINK)
or you could get a local power supply pack.
Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
Posted on Jan 30, 2008
Anonymous
  • 313 Answers
SOURCE: i HAVE A DEWALT DC729 18V DRILL
is this a north american model.all i can find is model DC727 & DC728 model. charger model 9116 & battery is DC9096 may work.charger volts 110v ac. if your buying the individual part like batt & chgr its more expensive than buying the whole kit is cheaper. hope i answer your question
Posted on Jun 21, 2008
Anonymous
SOURCE: My Dewalt 7.2-18v charger model #dw9116 is giving
It means there is too high or too low a voltage coming into the charger. Check your chord.
I had the exact same problem. After using the necessary security bit to crack mine open, I found that the large capacitor inside had come loose and needed to be re-soldered.
That fixed my charger.
Posted on Aug 28, 2009
Anonymous
SOURCE: Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Posted on Feb 24, 2010
Repair Ahjoshe
  • 885 Answers
SOURCE: my charger displayed cold/hot pack
This is indicating the battery is too hot to charge, usually after coming off the tool right after some hard work. During the charging process the battey heats up so if you charge a hot battery, thereby making it hotter, you shorten the lifespan of the battery considerably. If you are getting a hot/cold pack delay indication on the charger, it should automatically start charging once the battery has cooled down sufficently.
Posted on Jan 30, 2012
I have a Lincoln 14.4-18v charger that showing a hot-cold pack delay. I have two batteries that haven't been used in a few days and the code comes up on both.
Insert batteries in and out of charger quickly several times to help make better contact, its worked for me in the past. seems like contacts get dirty and this gets them shinning again.
Jan 31, 2016 | Drills
Battery won't charge. Light pattern on the charger is " ._._._. Is this battery bad.
What is the residual voltage on your battery, if it is too low, charger will not engage. If the voltage is below the threshold allowed, simply jolt the Nickel Cadmium battery with a car charger to bring it up, then install on charger.
May 14, 2014 | Dewalt 18 Volt Compact Drill Kit
I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery. I tried charging them and back to back they all start off charging fine then charging light speeds up as to suggest their all bad. ...
May read instructions and see if charger is compatible of charging the two types of batteries you are charging ,,,,I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery
Sep 27, 2017 | Drills
My charger displayed cold/hot pack delay during charging
Feb 10, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
DeWalt 18v batteries charge light flashes quickly why?
Here are the codes for Dewalt Charger Flash indications:
---- ---- ---- ---- ---- ---- ---- Charging
------------------------------------ Charged
----- - ----- - ----- - ----- - ----- Hot/Cold Pack delay
- - - - - - - - - - - - - - - - - - - Replace pack
Feb 07, 2011 | Garden
Dewalt batteries
There are typically two to three contacts on battery packs. One to charge the battery, one to 120v (household) ground, and in the case of the third contact, grounding the battery pack.
Jan 21, 2009 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Jan 30, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
114 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
