Nikon D60 Digital Camera Logo
A
Anonymous Posted on Jan 16, 2014
Error message Message is Lock lens aperture ring at minimum aperture error message
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Sep 03, 2014
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443393
Points
622693
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as with a lens without an aperture ring.
The aperture ring is the one with a bunch of numbers on it such as 2.8, 4, 5.6, 8, 11, 16, and 22.
2 Related Answers
Anonymous
  • Posted on Sep 14, 2009
SOURCE: Format Error message
The aperture ring must be locked in position when using automatic aperture control. When the aperture ring is in any other position the 'format error' message appears and the camera is inoperative. Now that my ring is locked in position the camera works fine.
Anonymous
  • 55 Answers
  • Posted on May 16, 2011
SOURCE: Message: Lock lens aperture ring at
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
1helpful
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
1helpful
I have a Sigma 70-300mm lense which, when I attach it to my D300 gives me an error message of FEE. I was assured when I bought the lense that it would work. Am I doing something wrong?
You didn't specify which Sigma 70-300mm lens (Sigma has at least five different versions, and I'm not referring to the lens mount), but from the error message I assume the lens has an aperture ring. Turn the aperture ring to its smallest setting (largest f/number) and lock it in place. Control the aperture from the camera, the same way as on a lens without an aperture ring.
If the lens doesn't have an aperture ring, please reply to this post specifying the exact model of the lens. That's all of the numbers and letters around the 70-300mm, like AF, DGO, f/4.5, etc.
In p and ps modes on nikon n70 screen flashes F E E and will not take pictures. I do not recognize this error message
Check that you have the aperture ring on the lens set to minimum aperture, biggest f stop number. It should lock in that position, and there may be a small button to keep it locked there.
10helpful
2answers
I used the Nikon D90 with Lens Kit 18-200 mm, and I also bought the new Lens call Nikkor 75-300mm. But when I connected the new one (Nikkor 75-300 mm) in my camera and took some pictures, after that I...
That's the Nikon error message for a lens with aperture ring set to something other than the minimum (i.e. highest number).
The camera insists on controlling the aperture ring, and to do so, the ring must be set to the minimum setting.
Unless it is a "G" lens, which has no aperture ring whatsoever.
The camera body sets the aperture of the lens wide open while auto-focusing, and displaying through the viewfinder. When it comes time to flip the mirror up and take a picture, the camera dials the aperture to the setting you (or the camera) have selected.
2answers
Error code eFF
This normally indicates that you're using a lens with an aperture ring, and the ring is not locked in position. Turn the aperture ring on the lens to its smallest setting (largest f/number) and lock it if the lens has a lock. Control the aperture from the body, just as with a lens without an aperture ring.
If the lens doesn't have an aperture ring, could you reply to this post and specify what lens you do have on the D100?
Error message FEE on aperture
Make sure the lens is mounted on the camer fully. Make sure the aperture ring is set for the largest numbe like 22 or 32 if the lens has it. Some lenses have a lock to lock the aperture ring on the largest number for you. Also make sure the lens you are using is compatible with the F65 camera. if the lens is older then it will not give you any electronic data and the camera will never give you the f information in the viewfinder.
1helpful
Nikon D80 error message rEE
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Err message appears on the display
You did not mention the error message. However, If your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
ERR message
unmount and remount the lens. Make sure you have the aperture ring on the lens set at the minimum f-stop number, ie f22, f32. There should be a small tab on the lens to lock the aperture ring in that position
9helpful
What does the fEE error message displayed on an SLR camera mean?
The "fEE" error indicates that the camera is not communicating with the lens. The lens may not be attached to the camera properly, or if it has an aperture ring, it may not be set to f22 (or the highest aperture number of the lens) - which is normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this from occuring again. The fEE error message Set to f22, or the highest aperture number - normally marked in orange. Note the locking switch.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
