Nextbook Premium Series Next7P12 Logo
A
Anonymous Posted on Jan 16, 2014
Can i upgrade firmware - Nextbook Premium Series Next7P12
Download firmware for 9xn I need upgrade to 7.0
You need to go to the manufacturers support site for any firmware downloads.
Forgot my password how do I factory reset my
Accoruding to the Polaroid website, you can do this, but it does state:
IMPORTANT! Please make sure that you backup your files to a computer before you update your tablet's firmware. All content will be deleted. You can re-download your purchased and/or free apps from the Amazon Appstore (or other appstores) once the firmware update is completed.
Here's the link to the READ ME.
Polaroid Tablet Support Site
Remember, it is very important to find your EXACT model number AND build number located on the back of the tablet before performing a firmware upgrade. Performing an upgrade to the wrong tablet will result in the tablet being "BRICKED", rendering it useless as well as voiding your warranty.
I hope this helps and thanks for using fixya!
1helpful
Firmware upgrade failed
Similar problem on my Samsung Galaxy Note 8 when trying to upgrade to Kit Kat 4.4.2. Since my device had been rooted is registered as "Modified". There were dozens of posts instructing me to download drivers and decompilers and more software to trick the update server into seeing my tablet as "Official". Since a firmware upgrade will unroot the device anyway I simply used KEIS connecting with USB and it was effortless. Just make sure your device has at least 50% battery.
Firmware upgrade file
This is normally done in the settings. Look under 'about' for software updates.
3helpful
What to do when your HKC tablet wont charge
I had this problem with 2 of these tablets. I got one of hem working by upgrading the firmware. They had an issue with angry birds and some other games not working which they resolved with this firmware update. Go to their web site and follow the firmware update instructions. I think it seems to be a software issue with the battery and not the battery itself. After I upgraded, the tablets no charges and plays angry birds. I do have another one that didn't work when I did this but it's worth a try. Here's the link for the download and instructions. http://www.hkcdigital.com/upgrade-your-tablet/
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
3helpful
2answers
I am trying to upgrade my firmware from 2.2 to 2.3, i followed the intruction on the internet, then after i run the procedure instead of seeing pass messages after upgrade it shows faild. the problem i...
Good day. I''m afraid you might have accidentally got the Operating System of your Samsung Tab corrupted. Im referring to your firmware. Usually if the firmware upgrade failed you need to retry it until it be successful. If you restart it or discontinue the process it will cause your Samsung Tab to be corrupted resulting into failure of the boot up process. You might need to contact samsung tech support for this or bring your equipment to the nearest center. They might need to check the software install and usually their software specialist will fix it for you. Sorry for what happen with your tab but i know the samsung repair center can fix it for you. Hope this information will be helpful to you. Have a great day.
Top Nextbook Tablets & eReaders Experts
NOEL
NOEL
john h
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
