SOURCE: My Playstation2 SlimLine SCPH-75001 does not read
According to the symptom The lens of your PS2 needs replacement, Contact any expert nearby and replace the lens and your console work fine again.
Thanks for using fixya.
SOURCE: PS2 slim SCPH - 75001 won't read any disc or let the disc spin
the same problem happened to me so i went out and bought a new 1 and it works great
SOURCE: sony2 slimline model scph-70002
Hi gollywog,
The laser not moving sounds like the connection from the motor that moves the laser to the motherboard has become dsiconected. You can usually get movement of the laser, and the only reason is something is wrong with the motor or its connection to the motherboard.
SOURCE: Sony playstation2 model SCPH-77001 SERIAL FU46.....
Good ! but we need to do one more thing, before checking the resistance.
You should carefully mark the current location of the adjustments so you can go back to them if needed. When turning the adustments yiu only need to turn VERY SLIGHTLY.{ one degree at a time } Turning to the right is increasing the Voltage and to the left is decreasing it.Oh you will see two Controls, one for the DVD and THE OTHER FOR THE CD.This is what you been waiting for : DVD should Read { 650/ 1000 ohms}
CD ={ 950/1200 ohms}....the DVD control will be on the left and CD on the right, facing you.or upside down.
Good luck.
diode;
SOURCE: rock band won't play on my playstation2 slimline
We had the same problem, we even went and bought a whole new Rock Band. My husband turned our PS2 slimline on the side and it started working. I don't know why or how, I just know it worked for us. Give it a try and I hope it works for you also.
