Question about Vizio GV47LF Television
No picture or sound, light comes on in the front and have to unplug tv to turn it off.
Picture lost sound lost as if tv was shut off but power light stayed on. cannot shut off tv without unplugging at power source. vizio 47" lcd I have a Vizio 47" HDTV model number GV47L FHDTV10A. I have no picture or sound, but i do have power, the vizio light comes on with i turn the tv on, but i can only shut it off if i unplug it.
  • Michael Mitchell
    Michael Mitchell Jul 08, 2013
    I have the same problem but the boards are not the same it is a vizio 42" M421VT does anyone have any ideas for this model it sounds like the same issues just a different board with different circuits... PS the motherboard was replaced by a tech and within a week the same problem continued I think it is a over heating or possibly a capacitor issue but there are no signs any ideas???
  • Anonymous Mar 26, 2014
    I have a vizio 40 inch series smart tv upon set up we lost picture but have sound ideas anyone
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
  • 2 more comments
  • sgtwicki Sep 21, 2010
    My Vizio had the exact same symptoms, so I applied the very same fix. I bought a standard fuse holder and fuse from Radio Shack and soldered wires to the blown fuse. Now if it ever blows again, I just pop in a new fuse.
  • grash2
    grash2 Mar 29, 2012
    Same problem, bought 4 micro fuses from Radio shack ($2.00 for 4 fuses) soldered the new fuse over the bad one, tested and the TV was alive and well, total cost for the repair $0.50 cents!!! and about 2 hours labor taking the TV down, removing the screws soldering the fuse and then replacing the screws and remounting the TV again, thanks for the information to do this simple fix!!!!
  • Sonicpeace Aug 24, 2012
    Incredible! This fix worked! I'm a 57 yr old woman with interest in electronics, but I had to learn how to use a multimeter and I had never soldered anything before in my life! I spent hours on YouTube learning to do these 2 things. The fix itself took less than an hour. Using multimeter, I found the bad fuse (teeny tiny white one 1.5A, upper right-hand corner of the main motherboard). Most time expended was looking for the fuse at RadioShacks, Frye's Electronics etc. Didn't find the tiny fuse (I don't think you can find it in any store). But I did the by-pass fix (thanks sgtwicki and grash2!!!). Got a fuse holder and regular barrel fast-acting 1.5A fuse (glass w/silver cap ends, about 1.4" long). Soldered each end of holder wire to fuse ends. Like doing surgery!! Get a "Helping Hands" tool -- very crucial to your success. Get pliers to flatten wire ends. Buy the smallest 60/40 solder wire. Don't use the bigger standard wire cuz beads will be too big and will cause short circuit somewhere. Find the bad fuse and do this fix! It works!
    Thanks also to jerry_tomlin and Peter_Campo -- all comments were so helpful. This really works!
This is an outstanding repair suggestion. I had the same symptoms and just completed soldering in a fuse as suggested (actually I attached hookup wires to the blown fuse on the board and connected in a fuse holder so that if it blows again the replacement will be simpler). 1.5 hrs labor and a few spare parts around the house and my TV works like new. Thanks for posting.
Posted on Jul 06, 2009
I see a couple sizes for the fuses. Did you use the 5x20mm or the 3.6x10mm fuses? the 5x20 have fuse holders which would be easier to solder on.
Posted on Jul 14, 2009
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Vizio Expert
  • 158 Answers
Your main board is bad. Call company if under warranty.
Posted on Sep 03, 2015
If you are familiar with the old glass car fuses that is what they look like but are white( I believe ceramic) with silver caps on each end and soldered/hard wired directly to the board. You cannot remove them without patience and a soldering iron. You can, with an ohm meter go across (touch leads of ohmmeter) to each end of the fuse to see if you see a short. Depending on how accurate your meter is, it should read 0 ohms or show some type of continuity/connection between the two leads of your meter. Hope this helps?
Posted on May 12, 2015
    New Friend:
Can somebody help me with my 37"? not sure exactly where this fuse is? pictures?
Posted on Oct 04, 2013
6ya staff
SOURCE:
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
Vizio vo47L 47" LCD. No
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
More specifically on #1 and #2 - capacitors either bulging, leaking, or exploded.
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!@#$
Feb 04, 2011 | Vizio VO47L 47 in. LCD TV
I have a 42 inch Gallevia model GV 42L. When TV is initially turned on blue screen comes up for about 2 seconds, it then goes black and a screeching noise comes through both speakers on the TV. No...
The power source has failed - the sound is the source that autooscillates because even its protections have been damaged and are no longer capable of safely shut it down.
It's a big failure so call a repairman, ther's nothing more you can do.
Aug 31, 2010 | Vizio SV470XVT 47 in. LCD TV
I have a Vizio VW37LHDTV10A LCD t.v. set that was built in august 2007. The power will come on and I can see the back light turn on. However, the screen stays black and there is no picture or sound. Then...
My friend, I recently fixed a vizio vw37l with the same problem but it was the lcd controller.
hope this helps a bit to diagnose your problem
Aug 27, 2010 | Televison & Video
47" vizio died
Very high failure rate on this brand. Even after repair, something else will fail. Cut your losses and buy a brand name set.
Mar 25, 2010 | Vizio SV470XVT 47 in. LCD TV
Vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
May 18, 2009 | Vizio VO47L 47 in. LCD TV
Picture on Vizio HD 47" LCD TV freezes
It sounds like a main board failure but it could be the power board as well, to find out your going to need to test the power supply voltages when it quits
Nov 26, 2017 | Televison & Video
Vizio GV47LF Television Logo
24,421 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
