Hi Nancy:
The first thing that I would be suspicious of would be the starter. What happens when you try to start the car? Does the starter turn over? Is there a clicking noise? Did the car run fine after starting with the grinding noise? If it did, then the grinding was probably associated with the starter. If you pull the starter and the little gear on the pointy end is all chewed up you'll be on your way to solving the problem. If you're lucky, a rebuilt starter will probably be most cost effective and hopefully (usually) the ring gear will be OK.
Hope this helps.
may be the backing plate is hitting. or it may be the wheel bearing is bad. check by making turns and see if the noise goes away or starts grinding like a washing machine. IF grinding is worse replace wheel bearring.
Can be a tensioner pulley with bad bearings or the rear drum bearing is shot. When the rear drum bearing goes bad, the drum drops slightly and starts rubbing and making all sorts of terrible noises. I would not run it like this as the pivot on the rear of the drum that rides in the bearing could be cutting into the support. Not a good thing.
Newer washers are designed with a food grinder inside to help grind up large pieces of food. What you are hearing is the grinder doing its job. You do not need to worry about the noise. It should go away after a while as the food particle is ground up.
the unit has a "food chopper" inside the pump sump. it is to chop up "food" items and not bones, seeds or other items. you can keep running the unit and see if after 2 or 3 loads the noise goes away. ie: the item get chopped up small enough to go out the drain. if it doesnt go away, then you will need to get into the wash pump and see what is stuck in the sump. its not hard to take apart and you will find whatever shouldnt be in there.
also just replaced the motor com board when this started
