Dell Inspiron 6400 Notebook Logo
Posted on May 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
To solve code error 0146 and 0148
Hi i wanted to install windows xp but it show messeges after diagnosing the code error is 0146 and 0148 i have dell inspiron 1525 , when i try to reinstall the os the dell media centre dvd is not working , after that i run the diagunes test i recevied the errors error code 0148 hard optical deive 0 incorrect status 1A error
Lee Hodgson
Level 3:
  • Dell Master 4,810 Answers
  • Posted on May 29, 2009
Lee Hodgson
Dell Master
Level 3:
Answers
4810
Questions
Helped
1782303
Points
15941
Hi there.
0146 error is DST Log contains previous error(s).
0148 error is
IDE ERROR: status (x) (s)
This could be a problem with the BIOS, restart the PC and hit F2 as it starts up, this will take you into the bios, reset the bios to default setting, press F10, save and exit the bios, the PC will restart so perform another check and see if the same error code return.
Good luck
Sir, I want to change my o/s from windows 7 to xp on lenovo g450 but unable to do the same as error messege apears.let me know the right process to do the same . akash
If I understand you correctly, you want to downgrade from Windows 7 to Windows XP.
What error messages are you getting? A great deal of new hardware just can't be directly supported in XP.
My computer with windows xp after a while dumps its memory
First off, have you installed any new hardware or software/drivers recently?
Random memory dumps are caused by out-dated or incorrect drivers, or malfunctioning hardware.
In most cases you can reference an error message by going into your event logs using
start, run
type
eventvwr.msc
Click on system or application
Dr Watson is a program in windows xp that is used to diagnose these error messages. Look at this link
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/drwatson_overview.mspx?mfr=true
6helpful
2answers
Error messege''Failed to write''
install a software called nero burning rom.. itz a gr8 software....
please vote for me...im sure this will solve your problem...
2answers
Insataling windows xp problms
If u just want XP . Source a dos boot ( u can get files from internet), format the HDD .create main partision for windows xp and try installing
1helpful
HELP! Laptop will not boot up!
Try an XP repair:
Boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
8helpful
2answers
You may be a victim of software counterfeiting
THERE ARE NUMBER OF METHODS BUT FOR YOU THESE 2 METHODS ARE GOOD
1) METHOD:-
TRY SYSTEM RESTORE.
2) METHOD:-
2.1) LAUNCH WINDOWS TASK MANAGER.
2.2) End wgatray.exe Process In Task Manager.
2.3) Restart System In Safe Mode.
2.4) Delete wgatray.exe from c:\Windows\System32.
2.5)
Delete wgatray.exe from c:\Windows\System32\dllcache.
2.6) Launch RegEdit.
2.7) Browse the following key HKEY_LOCALMACHINE\SOFTWARE\MICROSOFT\WINDOWSNT\CurrentVersion\Winlogon\Notify.
2.8) Delete The Folder "WgaLogon" and all of its component.
2.9 ) Reboot System.
3.0) BE HAPPY NOW.... AND NEVER EVER INSTALL WINDOWS GENUINE ADVANTAGE NOTIFICATION IN WINDOWS UPDATE OTHERWISE YOU HAVE TO REPEAT THE DAMN PROCESS AGAIN.
IN ORDER TO THAT FOLLOW THIS
START
--> CONTROL PANEL--> AUTOMATIC UPDATES --> CHOOSE THE OPTION """"""""""""Notify me but don't automatically download or install them"""""""""""
When u use this option whenver your system detects any new WINDOWS UPDATE choose the updates which u want to install... DONT INSTALL WINDOWS XP SERVICE PACK --3.
Problem of blue screen error messege
you have installed the inf setup or not, install all the updated drivers of your motherboad
26helpful
3answers
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
IT'S A VIRUS ??????????
If you have enabled raid and striped the drives together you cannot access them independently.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
