Canon SD850 IS power button broken, is there a replacement and how to fix it. I have the same problem. The power button on my Canon Powershot SD 850 IS is broken. I can still get it to go on and off sometimes if I use something small to press the button, but I would like to fix it. Any suggestions?
SOURCE: Canon SD 850 says lens error,
I bought a canon SD 850IS before 15 months back and now i'm getting "LENS ERROR". I didnt damage by dropping down or handling roughly and also i didnt used much.when i start my camera it showing LENS ERROR.... Is there any way to fix this issue by my self or should i take to canon service center?
Please help me....
Thanks in Advance,
Srinivasan.G
SOURCE: lens error restart camera but
Hi
Your
lens is defective needs to be cleaned, repaired or replaced. If you got sand in the gears it will definitely jam up the lens! Sometimes you can tear down the lens and clean out the sand, and if none of the gears are damaged the lens will then work properly again.
There are online places that will do it for a
decent price and there are others that overcharge by way too much.
I know this because I OWN ONE that charges a reasonable price to do the
repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
SOURCE: Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
SOURCE: When I try to turn on my Canon PowerShot SD850 IS,
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
